Was running fine, shut off now no start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 09-28-2018, 02:47 AM Thread Starter
So I took the truck out last night and it was running fine and died and now won't start. I recently rebuilt the engine from the ground up and the truck has been running phenomal until last night. It'll crank but won't fire. All the injectors have been re-oringed I changed the ipr while the motor was out it has a relatively new cps and icp and I converted to electric fuel running 70 psi at idle and now when I kick the fuel pump on to prime it's reading 95 and the regulator has not been turned up or moved since I've been running it. I have a hpop gauge from glow shift and the when the truck was running it would fluctuate ever so slightly at idle from about 450psi to 400psi or so and I never paid attention to it because it ran great. Over the time I've had the truck I've changed the icp sensor 2 times and each time they went bad the truck would run terribly but would start no problem and right now I'm at a loss for what it could be that's not letting the truck fire, any help is appreciated. Could the ipr make the fuel pressure go up with out the motor running?
Macher7.3 is offline
