Rough idle loud knocking - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 09-28-2018, 12:29 AM Thread Starter
Sinister_obs's Avatar
Ok so I have a 92 F250 swapped to a 95 7.3 Powerstroke. At idle the truck runs rough. About 3-5 seconds into starting the truck the cel comes comes on and the rpms increase by 200 and sounds like it’s running on 7 cylinders and knocks. Icp cpshave both been replaced. Plugged in a snap on scanner the other day and got a couple codes: P0380 P0475 P1283 P0264 P1298 P1293 from KOEO
P0478 P0470 P1211 from memory
All high pressure lines have been replaced injectors are rebuild and modified to 160/0
A couple weeks ago the truck lost power and would take 4-5 seconds to rev to 3000. Idm,engine harness, and engine bay harness have all been replaced as well. I’m at a loss for what could be goin on. Anyone got any ideas?
Sinister_obs is offline
post #2 of 5 (permalink) Old 09-28-2018, 04:04 AM
Re: Rough idle loud knocking
That's a whole bunch'o'codes. Since a lot of them are unrelated I would guess a PCM might be the culprit. Do you have a buddy you can swap with?
walt_mink is offline
post #3 of 5 (permalink) Old 09-28-2018, 05:28 AM Thread Starter
@walt_mink no I don’t. I don’t have to many people around here that even own these old 7.3s
post #4 of 5 (permalink) Old 09-29-2018, 12:25 AM
Alright, well, you've got a lot of codes here:
P0380 - Glow Plug Malfunction
P0475 - Exhaust Pressure Control Valve Malfunction
P1283 - IPR Circuit Failure
P0264 - Cylinder 2 Injector Circuit Low
P1298 - IDM Failure
P1293 - High Side Open Bank No. 1
P0478 - Exhaust Pressure Control Valve High
P0470 - Exhaust Pressure Sensor Malfunction
P1211 - Injector Control Pressure Sensor Above / Below Desired
To troubleshoot this, you need to look for commonality. One thing I notice is that these are all located/related to the top of the motor. Check the wire harnesses for any chewed or burnt wires. Also, check all of the ground straps - there are at least three going to the motor. What you're seeing looks like an electrical gremlin, not a massive mechanical failure.
post #5 of 5 (permalink) Old 09-29-2018, 03:08 AM Thread Starter
Walt_mink I couldn’t imagine what more it could be. I have driven the truck for a week now and haven’t had a problem with it other than the loud knocking and idle jumping up. All the engine harness has been checked over and repaired. The fuel bowl heater isn’t hooked up because I know those were a pretty common problem to burning fuse #22 which is also to the pcm main power
