E40D Transmission codes - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 09-26-2018, 07:31 PM Thread Starter
Christian123's Avatar
Just picked my truck up from having it scanned. 1996 f350 7.3 4x4. The codes pulled were P0603 (internal control module KAM error), P0344 (Cam position sensor), and P1728 (torque converter clutch). Also found out the fluid is burnt... if any of the experts could step in and tell me where I should go from here that would be great.
Thanks again,
Christian
Christian123 is offline
post #2 of 4 (permalink) Old 09-26-2018, 08:24 PM
Bugman's Avatar
Re: E40D Transmission codes
The 0603 will happen whenever you disconnect the batteries.
If it is running I wouldn't worry about the 0344 cam sensor problem.
Since you are having transmission problems I myself would say that you have a bad torque converter. Hopefully Mark K will chime in where with what he thinks since he is the transmission expert.
Burnt fluid could also be part of the problem since it won't lubricate as good as fresh oil.
Bugman is offline
post #3 of 4 (permalink) Old 09-26-2018, 09:32 PM Thread Starter
Ya I have a a feeling it could be time to rebuild, and I disconnected and reconnected batteries again, but it came back when I started driving on the highway. Also noticed it is running at a much high rpm, which Im sure also had to do with the tc. Im usually at around 1500 going 65mph, now Im at 1500 only going 50-55mph
post #4 of 4 (permalink) Old 09-26-2018, 11:38 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Most likely the torque converter is bad. You can usually tell by looking at the front face of the torque converter. When it slips it gets really hot and can turn the cover of the converter blue. If it's blue, the torque converter is toast.
Mark
The good thing about science is that it's true whether or not you believe in it. ― Neil deGrasse Tyson
Mark Kovalsky is offline
