hpop 95 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 09-26-2018, 05:39 PM Thread Starter
hpop 95
took my hpop out of my 95 had a nice leak on main gasket is there anything else should replace since i have it out , orings or anything, possible oring kits?
97biggreen is offline
post #2 of 2 (permalink) Old 09-26-2018, 08:32 PM
longjonsilver's Avatar
Re: hpop 95
Iím not sure if the 95 has the ď non-serviceable ď plug , Iíd replace that .
Iíd rebuild the IPR valve while you have it apart . Be careful that you donít loose the small check ball thatís in the pump when you remove the non serviced plug .
You might want to rebuild your fuel bowl too .
Diesel O rings.com has everything youíll need
longjonsilver is offline
