"bad regulator on new alt and batteries" - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 09-14-2018, 01:22 AM Thread Starter
I have a 1997 4wd 5spd. I recently replaced the alternator due to a faulty regulator, it was getting cherry hot. But it was still charging, the new alt doesn't get hot but it also doesn't charge. I just replaced the regulator plug as well and nothing changed.. help!!
Slack.77 is offline
post #2 of 5 (permalink) Old 09-14-2018, 02:20 AM
Patrick Feeley's Avatar
Re: "bad regulator on new alt and batteries"
Does the battery light come on and then go off when you start it? Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3Ē DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #3 of 5 (permalink) Old 09-14-2018, 04:25 AM Thread Starter
No the battery light just stays on
Slack.77 is offline
post #4 of 5 (permalink) Old 09-14-2018, 04:50 AM
Native Texan
masakimm's Avatar
Garage
check the fusible link at the solenoid. may have burnt it out. other wise verify u have voltages where ur suppose to at the alternator. Don't have my diagrams right now but should have 12v at the main wire then 12 volts from a fuse on one of the smaller wires and on the jumper wire if your truck has that can't remember when that changed. the other wire should be from ur gauge.
"Y'all have a wonderful"
"My name is Bob the guy floating in the lake with no arms and no legs"
TSGT Bob W Martin USAF 1948-2014
Upgrades:
masakimm is offline
post #5 of 5 (permalink) Old 09-18-2018, 05:44 AM Thread Starter
Turns out it was just one hell of a coincidence, the 2nd new alt was bad and everything is fine now
Slack.77 is offline
