Valve cover bolt sheared? Help needed! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 09-10-2018, 04:32 PM Thread Starter
Changing glow plugs so I got a brand new Digital Kobalt torque wrench. It worked well for torqing the glow plug to 14lbs but when closing up the engine, not so much. I set it to 98 as stated and the valve cover bolt with the stud on top for the air intake hose sheared clean with nothing sticking out.I do not reccommend this 200$ wrench. As luck would have it I dropped one of the other stud on top valve cover bolts for the oil stick also and cannot find it.
Question 1- Can I drive it with 1 missing?
2- What is the part number for the stud on top bolt? Where can I get a new one? I have Googled and come up empty. Please help.
1996 CC 4x4 auto
1995 Cab-n-Chasis manual
jking is offline
post #2 of 10 (permalink) Old 09-10-2018, 09:45 PM
Bugman's Avatar
Re: Valve cover bolt sheared? Help needed!
Are you talking inch lbs or ft lbs? If you torqued them to 98 ftlbs they will shear off every time. Factory specs only call for 72 inch lbs or 12 ftlbs.
For the stud just pull one of the bolts out and head down to the parts store and just tell them you want a stud a inch or 1 1/2" longer than the bolt along with a couple of nuts.
Bugman is offline
post #3 of 10 (permalink) Old 09-10-2018, 11:17 PM
2000 F350 SuperDuty 4x4
Calico5's Avatar
Those studs are metric, M8x1.25 (IIRC). They're kinda special, as the hex/nut is integral to the stud, not a seperate piece.
Here are some:
http://www.ebay.com/i/223135235194
Hardest part might be getting the broken piece out of the head...
~Al
Al in SoCal
AFE Intake; Garrett 38R; Turbine Jacket; Banks IC, BanksBrake
Melling LPOP, External Oil Cooler & Filter System
Stealth 4-line Twin HPOP,
Swamps 160/30's, HVHF IDM; DP-Tuner F5
Full R-R Fuel System, Pre-& Post-pump filtration
Mishimoto Rad & Tank; 4" Exhaust, Twin Aussie Stacks
SouthBend D-D Clutch; ZF 6-spd, GearVendors O/U Drive
Calico5 is offline
post #4 of 10 (permalink) Old 09-10-2018, 11:30 PM
Master BS'er
jamiesaun's Avatar
Just spin it out with a pick or something. If that doesn't work get a left handed drill bit.
98 inch lbs. Big difference, 12 times the difference actually.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #5 of 10 (permalink) Old 09-11-2018, 02:10 AM
Bugman's Avatar
I don't know if I would pay $40 for something that I can fix with a stud and a couple of nuts.
Place one nut on the bottom of the stud to act like a bolt. You'll need 2 nuts on top to tighten it up but then just take the two nuts off and just use one for the attachment. Then if you have a welder or a friend with one you could tack the one nut into place so that you wouldn't have to deal with the top nuts.
You should be able to do that for less than $5.00
Bugman is offline
post #6 of 10 (permalink) Old 09-11-2018, 02:58 AM
Master BS'er
jamiesaun's Avatar
He said it sheered clean with nothing sticking out. I assume he means flush with the head. If there is some sticking out then the nuts wount even be necessary. Just spin it out with your fingers.
Brother James
post #7 of 10 (permalink) Old 09-11-2018, 03:41 AM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
You could also just head down to your local ford dealership and pick up a bag of valve cover bolts...done it before.
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
post #8 of 10 (permalink) Old 09-11-2018, 03:42 AM
Bugman's Avatar
I was talking about the replacement one.
I figured that he should already know how to get the broken one out of the head.
But a nut and welder can do a lot of things with sheared bolts/studs.
Bugman is offline
post #9 of 10 (permalink) Old 09-11-2018, 03:46 AM
Master BS'er
jamiesaun's Avatar
Oh I see. My bad.
Sent from my SM-G950U using Tapatalk
Brother James
post #10 of 10 (permalink) Old 09-18-2018, 07:16 PM Thread Starter
The bolt is discontinued by Ford, I have ordered on online from navistar. Part #1820515C1
1996 CC 4x4 auto
jking is offline
