Wiring Harness Under Steering Column - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 09-07-2018, 01:31 AM Thread Starter
Trying to figure out what this harness goes to. Pulled the dash out and got everything together but this. Can’t seem to find where it goes. There are 3 total harnesses coming out of a larger one, two of which go to the accelerator then this one. Took me too much time to put it back together. It’s a ‘97. Thanks.
File Type: jpeg EF443EAD-4DC4-4382-BF72-9E12D6BDC47D_1536280220310.jpeg (891.4 KB, 40 views)
Rocco34 is offline
post #2 of 4 (permalink) Old 09-08-2018, 03:01 AM
Patrick Feeley's Avatar
Re: Wiring Harness Under Steering Column
Only thing I can think of is he blower fan speed switch on the dash? Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #3 of 4 (permalink) Old 09-08-2018, 12:16 PM
alleged moderator
tjctransport's Avatar
trailer brakes??
tom
tjctransport is offline
post #4 of 4 (permalink) Old 09-08-2018, 03:52 PM
2000 F350 SuperDuty 4x4
Calico5's Avatar
Need a little more context to your picture...
Where's it coming out at (left side, right side, middle)? Take a wider shot of the under-dash area.
Al in SoCal
AFE Intake; Garrett 38R; Turbine Jacket; Banks IC, BanksBrake
Melling LPOP, External Oil Cooler & Filter System
Stealth 4-line Twin HPOP,
Swamps 160/30's, HVHF IDM; DP-Tuner F5
Full R-R Fuel System, Pre-& Post-pump filtration
Mishimoto Rad & Tank; 4" Exhaust, Twin Aussie Stacks
SouthBend D-D Clutch; ZF 6-spd, GearVendors O/U Drive
Calico5 is offline
