Engine removal - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By MeTo
post #1 of 10 (permalink) Old 08-16-2018, 04:25 PM Thread Starter
Engine removal
Does the turbo have to come off the engine in order for it to come out. Looks like it's a tight fit, thanks.
Taylorw16 is offline
post #2 of 10 (permalink) Old 08-16-2018, 04:39 PM
Native Texan
masakimm's Avatar
Garage
Re: Engine removal
it is easier. but I removed mine and reinstalled it with it in place so it can be done.
"Y'all have a wonderful"
"My name is Bob the guy floating in the lake with no arms and no legs"
TSGT Bob W Martin USAF 1948-2014
Upgrades:
masakimm is offline
post #3 of 10 (permalink) Old 08-16-2018, 04:55 PM Thread Starter
Did you remove the core support to get it out?
post #4 of 10 (permalink) Old 08-16-2018, 06:51 PM
Native Texan
masakimm's Avatar
Garage
Re: Engine removal
Yes I had to replace it anyways plus was adding intercooler
Upgrades:
masakimm is offline
post #5 of 10 (permalink) Old 08-24-2018, 12:56 AM
Re: Engine removal
If you remove the hood, the core support does not need to be removed. I just did it to rebuild mine. You will need a lift that can lift the engine over the core support. I used a tractor and loader for mine. You also want to place a pice of plywood in front of the IC to protect it.
Cummins Junkie likes this.
97 F350 XL std cab, zf5, srw (converted), 4wd, 3.55s, stock wheels/tires & rebuilt 9.19
2 Donaldsons, 3" dp, ACs, T500, HV LPOP, Hydra w/PHP, DIY 60 gl tank w/6 gl sump, eFuel/Cat filters, Aeromotive RR, Auber instruments, 140v IDM, KC 300X 63/70/84, RiffRaff bellowed up pipes, 6.0 IC, 3" plenums w/RiffRaff inserts & SB 425HD
MeTo is offline
post #6 of 10 (permalink) Old 08-25-2018, 10:54 PM
Project Shamu
Lt.Dan's Avatar
I left the turbo on, and just unbolted the core support at the top and leaned it forward. Then the motor came straight up and out. If not, you pull the turbo, and rotate the motor 90*, then it comes straight up and out.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is offline
post #7 of 10 (permalink) Old 08-26-2018, 05:28 PM
79jasper's Avatar
Re: Engine removal
In the idis, always had to remove the oil filter. No matter what would always find a way to get hung up on it. Lol
Sent from my SAMSUNG-SM-G930A using Tapatalk
79jasper is offline
post #8 of 10 (permalink) Old 08-27-2018, 03:44 AM
Project Shamu
Lt.Dan's Avatar
Re: Engine removal
They all say the starter can stay too, but I caught mine on my motor mount and broke the engine mid plate! $100 for a used one on ebay, Ill never do that again, its only 2-3 bolts!
Lt.Dan is offline
post #9 of 10 (permalink) Old 08-27-2018, 04:00 AM
79jasper's Avatar
Re: Engine removal
3 unless it's a sd, iirc. Lol
79jasper is offline
post #10 of 10 (permalink) Old 08-27-2018, 06:08 AM
Project Shamu
Lt.Dan's Avatar
Re: Engine removal
Yeah 3 for OBS, and 2 for SD up to 03, then they went back to 3.
I think...
Lt.Dan is offline
