Fuel Pump Replace - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 08-13-2018, 12:36 AM Thread Starter
G-force's Avatar
Garage
Fuel Pump Replace
Hi, ran into some trouble trying to replace fuel pump. Cannot loosen banjo fitting from fuel pump, black plastic part on top. Have photo of part.
1997 F-350 7.3
G-force is offline
post #2 of 4 (permalink) Old 08-13-2018, 12:45 AM
longjonsilver's Avatar
Re: Fuel Pump Replace
That would be a fuel pulsation damper . There is a hex nut on the under side of it . Iím not sure what size it is as Iíve never had the pleasure of having to remove one , thank the Lord . Itís California only I think . Iím sure someone with experience with it will chime in. You might could get it removed with a crows foot and some patience, by the looks of the picture.
longjonsilver is offline
post #3 of 4 (permalink) Old 08-13-2018, 01:04 AM
Native Texan
masakimm's Avatar
Garage
i should be 1 1\8th i believe pulse dampener is a cali thing. you may have to pull the turbo to get to it with the dampener on there.
Upgrades:
masakimm is offline
post #4 of 4 (permalink) Old 08-13-2018, 04:16 AM
Bugman's Avatar
The nut is 1 1/4". Some have been able to remove the pump without removing the turbo on a California model and some have just removed the turbo to avoid the frustration of it being in the way. It also helps if you heat the wrench up a little and put a bend in it to get it onto the nut.
Bugman is offline
