Day with an OBS - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 08-10-2018, 03:59 PM Thread Starter
HilhavenFarm's Avatar
Day with an OBS
For several weeks my battery light would flicker and was probably the early sign the tensioner assembly was going out....This same thing happened with my 87 IDI. Obviously I did not learn.
On my way home Tuesday from Winston Salem and hear the dreaded sound of Belt Break.
Broke my rule of taking everything out of truck to clean it the prior weekend after vacation, so not one d**n tool in truck.
Second rule broken, was not having a spare belt as usual.
I give truck a roadside diagnosis and appears belt just snapped. Nothing loose or seized.
I run to Oreilly's and get a new belt and home for tools.
I replace belt and all appears good, take off home and less than 5 miles I see battery light and start losing power steering, etc.
I get to a local store and pull up to pump for fuel. Temp light comes on 500' feet before stopping. I get out and no vacuum pump. See pictures.
I make another trip to Oreilly's and buy a new vacuum pump. Install in parking lot during thunderstorm and then tensioner gives as I try to reinstall belt. I would have bought one but store did not have one in stock and it was 8:30pm.
I am done at this point. I head home and regroup, we trailer truck to house at 11 pm.
Next day pick up new tensioner and put it all back together. She is purring like a kitten.
Any thoughts on what caused VP failure? It was a used part from a spare engine @ farm.
https://imgur.com/a/CA004Oc
1996 F350 XL Crew Cab LB 4x4 3:55
Former Ft. Bragg/Pope AFB Truck
DieselSite Coolant Filter
Riff Raff Diesel Turbo & Y Boot Kit
Riff Raff Diesel HPX
Mile Marker 449SS Manual Hubs
1987 F250 XLT Lariat LB 2WD 4:10
6.9/7.3 IDI Swap-SOLD
2010 John Deere 5055D
1974 Deutz 5506
2950 hours-"The Tank"
HilhavenFarm is offline
post #2 of 8 (permalink) Old 08-10-2018, 04:35 PM
Native Texan
masakimm's Avatar
Garage
Re: Day with an OBS
Send that gates tensioner back they are junk. get a real motorcraft tensioner or u will not be happy.
"Y'all have a wonderful"
"My name is Bob the guy floating in the lake with no arms and no legs"
TSGT Bob W Martin USAF 1948-2014
Upgrades:
masakimm is offline
post #3 of 8 (permalink) Old 08-10-2018, 04:49 PM
PSN intsigator
heavydoc's Avatar
Re: Day with an OBS
Looks like a bearing failure
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is offline
post #4 of 8 (permalink) Old 08-10-2018, 05:31 PM
PSN intsigator
heavydoc's Avatar
Re: Day with an OBS
Update that tensioner to a dual tensioner too
heavydoc is offline
post #5 of 8 (permalink) Old 08-10-2018, 05:40 PM Thread Starter
Re: Day with an OBS
I agree. I had to take what was available to get by, Hell it says China on the pulley, at that point I knew. Will move on this.
1974 Deutz 5506
post #6 of 8 (permalink) Old 08-10-2018, 05:41 PM Thread Starter
Re: Day with an OBS
This incident made me research options. Is this the same as SD conversion?
1974 Deutz 5506
post #7 of 8 (permalink) Old 08-10-2018, 06:18 PM
PSN intsigator
heavydoc's Avatar
Re: Day with an OBS
Yep
heavydoc is offline
post #8 of 8 (permalink) Old 08-10-2018, 06:29 PM
Native Texan
masakimm's Avatar
Garage
Re: Day with an OBS
if u want to do the dual tensioner go online and get a BT-50 motorcraft tensioner. the mod is easy to do.
Upgrades:
masakimm is offline
