Fuel system issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 08-05-2018, 07:30 PM Thread Starter
Angry Fuel system issue
Is their a second fuel pump somewhere on a 97 Powerstroke truck. I have changed the valley pump but still is not running.
Memory Brock is offline
post #2 of 5 (permalink) Old 08-05-2018, 07:58 PM
Bugman's Avatar
Re: Fuel system issue
No there isn't.
You might want to post this in the correct section and describe what is going on other than fuel system problem.
Bugman is online now
post #3 of 5 (permalink) Old 08-06-2018, 12:23 AM
alleged moderator
tjctransport's Avatar
sorry, this was my mistake. i moved the post to the wrong forum.
tom
tjctransport is offline
post #4 of 5 (permalink) Old 08-06-2018, 01:34 AM
Bugman's Avatar
At least you got it into a 7.3 forum
post #5 of 5 (permalink) Old 08-06-2018, 02:53 AM
Moderator
Sbluke55's Avatar
Sometimes it's hard to prime the system after you change the pump. While cranking test your fuel pressure and report back. Crank for a little bit and refill the fuel bowl. You can crack the return line from the heads to the regulator to help bleed some air.
01 f-250, Standard
Sbluke55 is offline
