Speedo recalibrate - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 08-05-2018, 05:31 PM Thread Starter
Speedo recalibrate
I have recently swapped to 35” tores and 4:10 gears. Previously I had 285/75r16 and 3:55 gears. I have read a couple forums on how to recalibrate the speedo, but will this affect my shift points at all? I did a comparison calculator and it seems like stock tires with 3:55 and 35 with 4.10 are pretty close to equal.
Any help or advice is helpful. Does anyone know what code I need for the 35s?
97 F250HD XLT. 4x4 7.3 CCSB, 140,000 miles, 33" tires, 355 limited slip rear axle, 4" turbo back and 6637 Intake, glow shift gauges, PHP 6 position chip.
I don't know what's next.
PSD ADAM is offline
post #2 of 4 (permalink) Old 08-05-2018, 06:36 PM
alleged moderator
tjctransport's Avatar
Re: Speedo recalibrate
the shift points are controlled by the computer coupled with engine RPM's and VSS signal.
so recalibrating the speedometer should not change shift points.
tom
tjctransport is offline
post #3 of 4 (permalink) Old 08-05-2018, 11:52 PM Thread Starter
Correct but do I need to changed them with the gear swap?
PSD ADAM is offline
post #4 of 4 (permalink) Old 08-06-2018, 05:47 AM Thread Starter
Never mind, found my answer
PSD ADAM is offline
