6R140 to 7.3? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 08-02-2018, 09:27 AM Thread Starter
6R140 to 7.3?
What would it take to mate these two together? Anyone done this yet? The notion here is a stand alone controller, but not familiar with bell housing configuration etc etc. My understanding the 6R140 is a pretty robust tranny in stock format and would handily manage out puts even from a spiffy 7.3.
Thanks,
j
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, DP 4” exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
post #2 of 16 (permalink) Old 08-02-2018, 09:35 AM
PSN intsigator
heavydoc's Avatar
Re: 6R140 to 7.3?
Not real sure, but could be interesting!
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is offline
post #3 of 16 (permalink) Old 08-02-2018, 09:54 AM
79jasper's Avatar
Re: 6R140 to 7.3?
Bell housing is different.
Sent from my SAMSUNG-SM-G920A using Tapatalk
79jasper is offline
post #4 of 16 (permalink) Old 08-02-2018, 09:57 AM
PSN intsigator
heavydoc's Avatar
Re: 6R140 to 7.3?
Well that sucks
heavydoc is offline
post #5 of 16 (permalink) Old 08-02-2018, 11:00 AM
BigRed02
BigRed02's Avatar
Re: 6R140 to 7.3?
Billet adapter?
Sent from my iPhone using Tapatalk Pro
2000 F350 CCLB 4x4 7.3L, 4R100, 6637, 4" MBRP turbo back
2000 F250 Red 4x4 Ext. Cab, 7.3L DI, ZF-6
2005 Ranger Dark Gray, FX4, 4 dr, 4.0 SOHC, 5r55e
2015 Ford Transit 3500, Dark Gray, HR EX, 3.5L ecoboost, 6 speed select shift
2011 Edge Limited Black, 3.5L
BigRed02 is offline
post #6 of 16 (permalink) Old 08-02-2018, 11:41 AM
Native Texan
masakimm's Avatar
Garage
Re: 6R140 to 7.3?
u would need a fly wheel that bolts to the 7.3l crank and the 6r torque converter. an adaperter plate to bolt to the 7.3l and to the 6r bellhousing. then u would need a trans controller that can controller the 6r plus shifter cable or custom shifter. plus drive shafts will have to be made to go from the 6r to the 7.3l
"Y'all have a wonderful"
"My name is Bob the guy floating in the lake with no arms and no legs"
Bob W Martin 1948-2014 USAF
Upgrades:
masakimm is offline
post #7 of 16 (permalink) Old 08-02-2018, 11:43 AM
Native Texan
masakimm's Avatar
Garage
Re: 6R140 to 7.3?
And don't forget new trans tunnel in the floor for that big trans and a new mount to hold it smaller exhaust to squeeze past it. and who knows what else.
Upgrades:
masakimm is offline
post #8 of 16 (permalink) Old 08-02-2018, 12:01 PM
Moderator
Sbluke55's Avatar
Re: 6R140 to 7.3?
Even if you can get it to bolt up. Nobody has an aftermarket controller to run it.
01 f-250, Standard
Sbluke55 is offline
post #9 of 16 (permalink) Old 08-02-2018, 02:37 PM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Re: 6R140 to 7.3?
Why not just get a built e4od and be done with it?
Sent from my SM-J320V using Tapatalk
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
post #10 of 16 (permalink) Old 08-02-2018, 04:06 PM Thread Starter
Re: 6R140 to 7.3?
Yes it would seem there are no controllers at this time..... hmfph... oh well back to collecting parts for a ZF conversion.
JCart is offline
