Missing in one of the front pass side cylinders - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 07-28-2018, 08:35 PM Thread Starter
I have a 1997 7.3 ZF5 that got new injectors 15k ago. Everything was fine until the other day. I was driving on the highway and then came to a stop at the toll booth and my truck instantly started missing. I got home and unplugged each of the four valve cover harnesses individually. When I unplugged the front passenger side harness the truck ran the same so I was able to isolate the problem to those two cylinders. All eight injectors buzzed. I put a new valve cover gasket and a new under valve cover harness as well as a new pig tail for the outside of the valve cover and it still misses in one of the two cylinders. I even unplugged each of the two injectors individually and it still ran the same. Someone told me to make sure the push rods aren't bent so I pulled out all four individually. One may be a tiny bit bent. When I roll it on a table you can see it rolls flat and then you can see it's not completely straight. Does anyone have any ideas on what it may be?
Melamed555 is offline
post #2 of 3 (permalink) Old 07-30-2018, 01:23 PM
Moderator
Sbluke55's Avatar
Re: Missing in one of the front pass side cylinders
Sounds like you might have a bad wire in the engine harness. I would ohm it out.
01 f-250, Standard
Sbluke55 is online now
post #3 of 3 (permalink) Old 07-31-2018, 01:22 AM
Patrick Feeley's Avatar
Let me guess: Water in the IDM? (I saw your discovery on one of the other forums ... cheating I know). Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
