No tach - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 07-26-2018, 03:50 PM Thread Starter
PolanD RuNz iT's Avatar
No tach
My truck has been apart for ~8 months and while it was I took the gauge cluster apart to convert to blue LED’s. Finally plugged it in a day or so ago and everything works but the tach. I have the infinity from DP tuner (plugs into OBD II port) and it reads the rpm, which makes me believe the issue is in the cluster/ dash and not the CPS. Can anyone point me in the right direction?
1997 F-250 OBS
PolanD RuNz iT is offline
post #2 of 3 (permalink) Old 07-27-2018, 03:25 AM
Patrick Feeley's Avatar
Re: No tach
I would check the continuity of the White/Pink Stripe wire from the tach to the PCm connector pin 50 (97 Federal truck) or pin 19 (97 California truck). Cheers!
Patrick Feeley is offline
post #3 of 3 (permalink) Old 08-12-2018, 09:16 PM Thread Starter
Just getting on here to post an update: check the fuses. I had no O/D light or function, no cruise, no tach, some of the other dummy gauges weren’t working. Come to find out it was just a little 10A fuse. I thought they were all separate since I have had the truck completely apart, but that’s what it was.
1997 F-250 OBS
