Bad Turbo? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 07-24-2018, 01:02 AM Thread Starter
Diabolic1's Avatar
Bad Turbo?
I hooked up compressed air to the inlet side of my turbo. I plugged the return pipe coming off the IC to the spider and pressured it up to 15 pounds. There is a lot of air coming out the exhaust pipe! This surprised me because I thought by plugging the IC pipe, nothing could get into the engine. So does this mean either my spider is cracked inside or my turbo is somehow leaking intake air into the exhaust housing? It has to be one or the other and I doubt my spider could have a crack that large. You can hear and feel the compressed air out the tailpipe.
1997 CCSB, 7.3/E4OD
KC TP38R, CNC Fab Bellowed Up-Pipes, Full Force Stg 1 injectors, 3" DP, 4" exhaust, CNC Fab HPOP, Mark F E-Fuel, 7.3 Intercooler, 1.0 Exhaust Housing, TS Chip, remote coolant filter, and VB.
Diabolic1 is offline
post #2 of 6 (permalink) Old 07-24-2018, 01:11 AM Thread Starter
Diabolic1's Avatar
Re: Bad Turbo?
The inside of the spider is clean as a whistle and I canít see any evidence of even a hairline crack. The compressed air must be going through the inlet side of the turbo to the exhaust. Thatís the only way I can figure itís making it out the tailpipe. Is that normal?
1997 CCSB, 7.3/E4OD
post #3 of 6 (permalink) Old 07-24-2018, 01:40 AM
PSN intsigator
heavydoc's Avatar
Re: Bad Turbo?
I don't think you should be leaking compressed gas anywhere if your ic is plugged. Is your ccv hose still hooked to your intake pipe, or did you plug straight to the turbo?
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is offline
post #4 of 6 (permalink) Old 07-24-2018, 01:58 AM Thread Starter
Diabolic1's Avatar
Re: Bad Turbo?
Ahhh, yes. It is still hooked up. If it was blowing air into the CCV, would it find itís way to the tailpipe? That would be a relief. Turbo makes 35 pounds of boost with a WW2, and 1.0 Exh housing.
1997 CCSB, 7.3/E4OD
post #5 of 6 (permalink) Old 07-24-2018, 02:08 AM
PSN intsigator
heavydoc's Avatar
Re: Bad Turbo?
It is possible, I know I chased leaking air on mine and it was the damn cab hose.
heavydoc is offline
post #6 of 6 (permalink) Old 07-24-2018, 02:11 AM
PSN intsigator
heavydoc's Avatar
Re: Bad Turbo?
Mine was pushing through the dipstick
heavydoc is offline
