7.3 no start. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 07-14-2018, 11:25 PM Thread Starter
7.3 no start.
Was driving home and truck started losing power like empty fuel tank.pulled over wont start.towed it home and bypassed the tank with a pump to engine.still no strt.haveefuel conversion so no more bowl.tried spare cps.have tachometer movement andhigh white smoke.fresh oil md hpop is topped off and not drinking down.also tried good icp/ipr from running truck.have video of a.e. running.how to attach video or just use youtube?any advice appreciated.
jef1988 is offline
post #2 of 10 (permalink) Old 07-14-2018, 11:34 PM Thread Starter
jef1988 is offline
post #3 of 10 (permalink) Old 07-14-2018, 11:43 PM
79jasper's Avatar
Re: 7.3 no start.
Hpo system seems fine.
Almost has to be on the fuel side. Unless the injectors aren't firing.
79jasper is offline
post #4 of 10 (permalink) Old 07-15-2018, 12:03 AM Thread Starter
Have oil flowing from injector spouts and white smoke from exhaust.passes buzz test and injectors are clicking when cranking.could it be a stuck injector?
jef1988 is offline
post #5 of 10 (permalink) Old 07-15-2018, 01:26 AM
79jasper's Avatar
Re: 7.3 no start.
Doubt it. That wouldn't keep it from starting.
79jasper is offline
post #6 of 10 (permalink) Old 07-15-2018, 02:02 AM
Bugman's Avatar
Re: 7.3 no start.
The white smoke should be unburnt fuel.
How fast is the starter turning the engine over?
Put a meter on the batteries and see how much voltage is on them as you crank the engine over.
Do you have a place where you can check the fuel pressure?
Bugman is online now
post #7 of 10 (permalink) Old 07-15-2018, 02:08 AM Thread Starter
Voltage not an issue.had brand new interstate batteries and charger on.fuel pressure good.has regulated return system with gauge in video.recently replaced starter.cranks very fast
jef1988 is offline
post #8 of 10 (permalink) Old 07-16-2018, 12:59 AM
s10mike's Avatar
Your spare CPS, its a known good one?
s10mike is offline
post #9 of 10 (permalink) Old 07-16-2018, 04:14 AM Thread Starter
Yes CPS good.pulled out of my other 7.3 that is running fine to try.also Had a brand new ford cps as well.tach movement on all 3.btw the truck is. 97.f350
jef1988 is offline
post #10 of 10 (permalink) Old 07-22-2018, 09:02 PM Thread Starter
Anybody have suggestions on why to test next?
jef1988 is offline
