HARD LOPE sound HELP - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By tjctransport
post #1 of 5 (permalink) Old 07-13-2018, 05:44 PM Thread Starter
ps7.3945speed's Avatar
I have a 94.5 7.3 powerstroke. I took it camping and all was fine. Until I went to leave. I started it. It ran good for 3 seconds then died. Started it again ran good for 3 seconds then just started loping . Sounds like a miss fire or somthing. I have a new oem CPS. Going to put that in and see what happens. Can anyone help? Or at least kick my in the right direction. Thanks all
Sent from my SM-G920W8 using Tapatalk
ps7.3945speed is offline
post #2 of 5 (permalink) Old 07-13-2018, 09:55 PM
alleged moderator
tjctransport's Avatar
Re: HARD LOPE sound HELP
check the under valve cover harness for burn marks.
tom
tjctransport is offline
post #3 of 5 (permalink) Old 07-14-2018, 02:54 AM
CDavis90's Avatar
Garage
So check this video out from youtube. Mine was loping like this and it would do it in neutral or in park and my fix was the neutral safety switch.
CDavis90 is offline
post #4 of 5 (permalink) Old 07-14-2018, 06:57 AM Thread Starter
If so. what would that be a cause of?
post #5 of 5 (permalink) Old 07-14-2018, 11:28 AM
alleged moderator
poor contact will burn the pins, making it drop cylinders when the injectors don't fire.
ps7.3945speed likes this.
tom
