speedo drops out to the right - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 03-18-2010, 11:36 PM Thread Starter
reds97
reds97's Avatar
this just started, its done it twice. Im on my daily commute and cruising at about 70 - 75 mph, the speedo will fall all the way to the right and my odometer (digital) does blank ... all other gauges are reading normal...about 2 seconds later, they drop back to normal... anyone had this problem .... i dont now if its the speedo cable or what but im a little baffled... any thoughts will help
97 f250 EC LB 4"pipe no cat, dump at axle, unknown cold air...k&n filter...ya i know... 4" lift... lincoln sa 250 welder
reds97 is offline
post #2 of 3 (permalink) Old 03-19-2010, 12:14 AM
Re: speedo drops out to the right
There is no cable on it. It's all electronic. Usually when this happens it's losing power. Check the fuse for the instrument panel and make sure it's tight. No wires tapped into it. The connection on the back of the instrument cluster could be loose too.
rrranch is offline
post #3 of 3 (permalink) Old 03-19-2010, 01:02 AM
Hells coming with me
maverik2711's Avatar
this just happened to me like two days ago
Originally Posted by strokermax View Post
what do u mean troll no i dont hop out from under bridges as little kids walk by .
1997 Ford F250
Hypermax Stage 1's, custom tuned SCT chip, Dual 7 inch miter cut stacks, napa 6637, traction bars, suncoast built tranny Sold
2008 F250
H&S mini maxx
5" exhaust
S&B intake
dpf, egr delete
leveling kit
35" toyo's
20" moto metals
maverik2711 is offline
