Using MT250p for Trans Codes - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 07-10-2018, 04:54 AM Thread Starter
Diabolic1's Avatar
My OD light is flashing and i want to pull the codes but I cant seem to figure it out with the brick. I see koeo, koer, and clear codes, but nothing for trans codes. Can someone point me in the right direction?
1997 CCSB, 7.3/E4OD
KC TP38R, CNC Fab Bellowed Up-Pipes, Full Force Stg 1 injectors, 3" DP, 4" exhaust, CNC Fab HPOP, Mark F E-Fuel, 7.3 Intercooler, 1.0 Exhaust Housing, TS Chip, remote coolant filter, and VB.
Diabolic1 is offline
post #2 of 4 (permalink) Old 07-10-2018, 09:18 PM Thread Starter
Diabolic1's Avatar
Re: Using MT250p for Trans Codes
Nobody has one or can help?
1997 CCSB, 7.3/E4OD
post #3 of 4 (permalink) Old 07-10-2018, 09:26 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Trans codes are not reported separately. If it is capable of reading them they will appear in KOEO and KOER tests along with any engine codes.
Mark
ďThe good thing about science is that it's true whether or not you believe in it.Ē ― Neil deGrasse Tyson
Mark Kovalsky is offline
post #4 of 4 (permalink) Old 07-11-2018, 12:56 AM Thread Starter
Diabolic1's Avatar
Hmmm, I donít get any trans related codes but the OD light is flashing??? The OD light with flash about once a month and Every time it comes on, itís the first drive of the day. The trans goes into limp mode. I clear the codes with the brick and the flashing OD light goes out for another month.
If the light is flashing when I turn it off, it wonít flash again until itís started and put in gear, but if started and left in park, the light stays off. Mark, I know you are the man to talk to about these transmissions. That description point to anything in particular?
1997 CCSB, 7.3/E4OD
