1995 Fsuperduty ignition problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 12 (permalink) Old 07-03-2018, 08:44 PM Thread Starter
Just wanted to know if anyone had an issue with the key was in the igniton and I was going down the road with no winshield wipers, all the warning light lit up, could not tell what speed i was going. I tried to shut it off and it keeps running with the key pull out or in off position. I replaced the ignition cylinder (not OEM) and still does not work. I have to let the clutch out to shut off and when I do the fan and radio keep working and i have to disconnect the battery. HELP
jmusselman is offline
post #2 of 12 (permalink) Old 07-03-2018, 08:55 PM
79jasper's Avatar
Re: 1995 Fsuperduty ignition problems
Key cylinder has almost nothing to do with most ignition issues. Replace or adjust the switch.
Gruntís trophy likes this.
Last edited by tjctransport; 07-03-2018 at 11:38 PM. Reason: corrected typo, replaced switch for cylinder.
79jasper is offline
post #3 of 12 (permalink) Old 07-03-2018, 09:38 PM
Bugman's Avatar
The switch in on the column under the dash connected to the key mechanism by a rod.
Bugman is offline
post #4 of 12 (permalink) Old 07-04-2018, 08:58 PM Thread Starter
How hard is it to replace or adjust the switch
post #5 of 12 (permalink) Old 07-04-2018, 09:02 PM Thread Starter
could it be the actuator
post #6 of 12 (permalink) Old 07-04-2018, 11:38 PM Thread Starter
When i turned the key on, when this first started. Something inside thr key cylinder went loose. I hope its the key switch, but something tells me it might be the actuator. Let me anyone. Thanks for the info.
post #7 of 12 (permalink) Old 07-05-2018, 12:52 AM
Gruntís trophy's Avatar
About 20 mins for the switch, not to be confused with the cylinder that the pros on YouTube call a switch. Located under the steering column behind the lower section of the dash. 1aauto has a pretty good video you can watch and the part is less than $25
Gruntís trophy is offline
post #8 of 12 (permalink) Old 07-08-2018, 08:04 PM Thread Starter
Installed a new ignition switch and still does not work. Could it be the tumblers
post #9 of 12 (permalink) Old 07-08-2018, 08:45 PM
alleged moderator
tjctransport's Avatar
nope. most likely the actuator in the upper part of the column.
it connects the key cylinder to the rod that runs down to the switch.
tom
tjctransport is offline
post #10 of 12 (permalink) Old 07-08-2018, 11:30 PM Thread Starter
How about the actuator rod and if it is, are there any videos to replace it
