Clutch and oil pan needs replaced. Pull motor and trans together? obs 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 16 (permalink) Old 06-29-2018, 10:24 AM Thread Starter
I have a 1995 f-superduty with 7.3 powerstroke and zf5 trans. the clutch is fried and upon further inspection the oil pan is leaking badly and contaminating the clutch anyway so it looks like I need to pull the engine and trans or just pull the engine but should I drop the trans and lift the engone or pull it all together out the hood? what is the best practice if both need to come out. Keep in mind I'm working in a one stall garage with hand tools and jacks no air.
effsuperduty is offline
post #2 of 16 (permalink) Old 06-29-2018, 01:34 PM
josh77's Avatar
Re: Clutch and oil pan needs replaced. Pull motor and trans together? obs 7.3
while i've never actually tried it doubtful that you can get both out together without lifting the cab i know its fairly tight just pulling the engine
97ccsb 4x4
395k miles
3"dp 4" exhaust
digital egt gage & trans temp
aeroforce intercptor single gauge
swamps ts chip
baby swamps
kc turbos billet wheel and 1.0 housing
dana 60 swap (all stock 350 stuff for now)
77 f150 4x4 rclb
getting a 4.6 4v with m5od soon (in process)
josh77 is offline
post #3 of 16 (permalink) Old 06-29-2018, 02:30 PM
Master BS'er
jamiesaun's Avatar
Just pull the engine. No need to pull the trans to change a clutch if the engine is coming out. None of this sounds very fun with no lift or even a compressor. It's probably gonna suck ass bro.
How about this, pull the trans back, lift the the engine a few inches and pull the pan? Either way, change the rear main while you're there. I've seen a bunch of those leak.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #4 of 16 (permalink) Old 06-29-2018, 04:03 PM
Bugman's Avatar
To properly reseal the pan to the engine block the engine really needs to be upside down.
I don't know if I would go through all the hassles of trying to do it while it was still in the truck only to find out later that it didn't seal up properly.
Bugman is offline
post #5 of 16 (permalink) Old 06-29-2018, 06:26 PM
Master BS'er
jamiesaun's Avatar
Oh yeah? That's news to me
Brother James
post #6 of 16 (permalink) Old 06-29-2018, 08:19 PM
s10mike's Avatar
Oh yeah, upside down for 24hours. Enough time for the grey sealer from hell to cure
s10mike is offline
post #7 of 16 (permalink) Old 06-30-2018, 12:16 AM
Master BS'er
jamiesaun's Avatar
Well, I guess I better rethink all those times I've done it then.
Dustybumpers likes this.
Brother James
post #8 of 16 (permalink) Old 06-30-2018, 12:54 AM
Bugman's Avatar
Didn't say that it can't be done but it was the recommended way to do it.
Bugman is offline
post #9 of 16 (permalink) Old 06-30-2018, 01:04 AM
Master BS'er
jamiesaun's Avatar
Of course. There's nothing wrong with following the manual, but it's hard to make money that way.
Brother James
post #10 of 16 (permalink) Old 06-30-2018, 02:59 AM
Randy4614's Avatar
I know on my 93 IDI with a stick it was a real pain getting the engine out, think if I had to do it again I would slide the transmission back some then pull the engine.
Randy4614 is offline
