'Brake' Warning Light Always on - What'd I Miss? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 06-24-2018, 08:30 AM Thread Starter
1995 F-350 CC Longbed Powerstroke, 170k miles. This one's got me stumped. The dash 'Brake' warning light is always on when key in 'Run'. It started with fuse #13 in dash Fuse Panel repeatedly blowing and locking truck in 'Park'. Traced that to a wiring fault in the trailer. Disconnected trailer, replaced fuse, no longer blows.
The brake fluid level is right where it should be--jumped the green and tan wires together to confirm. Parking Brake is off--disconnected Parking Brake Pedal Switch wire to confirm, Brake wrng light still always on when key in 'Run' position. It's off when key is off. Brake lights and turn signals work normally. Can move gear selector lever in & out of 'Park' normally now.
Disconnected RABS Diagnostic Connection, grounded BK/O wire, 16 flashes on ABS light. ABS light goes on and off as it should when using ignition switch. What's wrong with this SoB Brake wrng light? Thanks.
WilST is offline
post #2 of 13 (permalink) Old 06-24-2018, 12:59 PM
Bugman's Avatar
Re: 'Brake' Warning Light Always on - What'd I Miss?
Odds are your vacuum pump is on its way out.
Bugman is offline
post #3 of 13 (permalink) Old 06-24-2018, 01:59 PM
alleged moderator
tjctransport's Avatar
yup. low vacuum will turn the brake light on.
tom
tjctransport is offline
post #4 of 13 (permalink) Old 06-24-2018, 06:20 PM Thread Starter
Thanks both for that. Where would that vacuum switch be? I have a vacuum tool to test it with.
WilST is offline
post #5 of 13 (permalink) Old 06-24-2018, 06:28 PM Thread Starter
Even simpler would be to jump the switch, or isolate it from ground, I guess?
WilST is offline
post #6 of 13 (permalink) Old 06-24-2018, 07:12 PM
alleged moderator
put a vacuum gauge on a vacuum port. if you have less than 19 inches vacuum, the pump is bad.
tom
post #7 of 13 (permalink) Old 06-24-2018, 07:52 PM Thread Starter
Ok, pulled the Low Vacuum Warning Switch connector and the Brake warning light finally extinguished. So it's a bad switch or a bad vacuum pump. I'll do the check tjctransport mentions, thanks, and go from there. I attached a page from the EVTM that shows the various parts that can cause a 'Brake' warning light to come on. What threw me off was the trailer short blowing fuse #13 AND the vacuum issue happening at the same time--weird.
Thanks for the help!
WilST is offline
post #8 of 13 (permalink) Old 06-24-2018, 07:57 PM Thread Starter
The file size of the camera was plenty big enough to read the wiring diagram. Must be reduced a lot when attached to a post, can't be read. Sorry, tried to contribute.
WilST is offline
post #9 of 13 (permalink) Old 06-28-2018, 11:31 PM
FullPullOBS's Avatar
Had the same issue on my 96. Go ahead and replace your vacuum pump. Try to find OEM and not reman. Itll go out again lol
FullPullOBS is offline
post #10 of 13 (permalink) Old 06-28-2018, 11:42 PM
don't play well w others
Dustybumpers's Avatar
X 4 on the pump.
Charlie
"A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Dustybumpers is offline
