Just changed injectors-did I fry IDM? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 03-18-2010, 02:44 AM Thread Starter
Senior Veteran Member
Centxdiesel's Avatar
Garage
I just finished changing out my injectors and while VC connectors were disconnected I decided to crank it over several times during repalcing all components. I did not pull Maxi-Fuse # 8 and I am wondering if I fried my IDM during cranking with VC connectors disconnected.
I have fuel bowel full of fuel, HPOP reservoir is almost full ( I topped off before trying to start), pulled one of the plugs in rifle barrel for oil- the one next to where a HPOP line attaches and have oil in there and under pressure. But while trying to crank I do not hear injectors clicking. I have 12 V to that fuse for IDM #8 but no start.
If it is IDM, anyone have an extra?
Thanks in advance.
Joe
Centxdiesel
1997 F250 XL SC, 512HP 1019TQ,
30% nozzle Hybrids from [email protected]
Adrenaline, Beans D-66,Beans E-Fuel,Valair Ceramic-Kevlar clutch.
Awesome Tuning by: Matt: from:
Centxdiesel is offline
post #2 of 17 (permalink) Old 03-18-2010, 05:19 AM
Patrick Feeley's Avatar
Re: Just changed injectors-did I fry IDM?
Injectors are not going to fire if the HP oil pressure does not reach 500 (or so) psi when cranking. It does take awhile to get it purged/filled enough to fire after an injector change. Cheers!
Patrick Feeley is offline
post #3 of 17 (permalink) Old 03-18-2010, 05:22 AM
<---- Funny
wriott's Avatar
takes ALONG time to get it to start after doing injectors....
Will
2002 F-350 CC LB 4x4 DRW
3 other PSDs, Low-Pro Freightliner, and 12 other diesel trucks
Random pics
wriott is offline
post #4 of 17 (permalink) Old 03-18-2010, 09:43 PM
What else?
smokyred's Avatar
Don't worry, you didn't fry the IDM by doing that.
It will take quite a bit of cranking to purge the air from the oil and fuel systems. Leave the injector harnesses unplugged until you're pretty sure you have fuel pressure, that is critical so you don't do any damage to the fuel side of the injectors. Then hook them up and crank it in cycles to keep the starter cool, taking breaks between trying to crank.
Dave
smokyred is offline
post #5 of 17 (permalink) Old 03-19-2010, 12:51 PM Thread Starter
Garage
Should I rely on the gauge I have installed in the fuel port on the fuel bowl regulator where the schraeder valve used to be at?
Centxdiesel
post #6 of 17 (permalink) Old 03-19-2010, 01:23 PM Thread Starter
Garage
While cranking it shows 25psi.
I am going to borrow a scan tool tonight and run a buzz test.
Centxdiesel
post #7 of 17 (permalink) Old 03-19-2010, 01:38 PM
mimetic's Avatar
I have an IDM for sale but like the other guys said it does take some time to get it to start.
Allen
2002 F250 Auto 2WD
4" exhaust, Gearhead Automotive Performance Tunes, Adrenaline HPOP, 3G Pod (PSI, Trans, Pyro), AIH Delete, S.S. HPX Line, Precision TC BD Valve Body, AFE Stage 1, Bellowed pipes, WW
mimetic is offline
post #8 of 17 (permalink) Old 03-19-2010, 09:01 PM
Thanks in advance.
Joe
I have one sitting around. $100 shipped gets it and if you don't need it I'll refund everything except shipping.
mgraveman is offline
post #9 of 17 (permalink) Old 03-19-2010, 09:12 PM
Lovin the Tuna
RedSmokey's Avatar
Get a scan tool, look at the ICP while cranking. If its not at 500 yet then thats your issue. Then just do like smokyred said above...
2001 F250
2000 F250
RedSmokey is offline
post #10 of 17 (permalink) Old 03-19-2010, 11:16 PM
What else?
smokyred's Avatar
Yes, that is on the return side of the system, so your injectors have fuel. Reconnect the electrical and crank it up!
Dave
smokyred is offline
