icp - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-17-2010, 11:56 PM Thread Starter
sgman's Avatar
icp
just curious what would happen if i were to unplug the icp and drive around like that? cause it sure runs better without it plugged in.
sgman is offline
post #2 of 5 (permalink) Old 03-18-2010, 12:32 AM
Patrick Feeley's Avatar
Re: icp
If you have an auto trans it will shift very hard (not good for tranny). It'll be running off default table values which probably isn't optimum for most situations anyway. Cheers!
Patrick Feeley is offline
post #3 of 5 (permalink) Old 03-18-2010, 01:38 AM Thread Starter
sgman's Avatar
Re: icp
yea the 3rd gear is rough thanks though i was just curious if it would be that bad to leave it unplugged.
sgman is offline
post #4 of 5 (permalink) Old 03-18-2010, 01:39 AM Thread Starter
sgman's Avatar
Re: icp
what do you mean by default tables though?
sgman is offline
post #5 of 5 (permalink) Old 03-18-2010, 05:22 AM
Re: icp
Since the PCM will not see an actual pressure signal from the ICP, it will use values that are contained in the computer based on all the other signals its getting (at least that's how I understand it). Cheers!
