Cruise control problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 06-17-2018, 10:40 PM Thread Starter
I have a 1997 Ford F-350 Powerstroke 7.3. I can not figure out the problem with the cruise control. It used to work and then one day it just stopped. Checked all the wires and there’s power everywhere. All brake lights work and the horn works too. I’ve searched and searched and can’t figure out the problem. Any suggestions? Trying to fix it before we go on a 9 hour trip with no cruise control lol
Joeydias97 is offline
post #2 of 4 (permalink) Old 06-17-2018, 11:41 PM
Re: Cruise control problem
Does your speedometer bounce around?
1995 Crewcab XLT 4x4 7.3, E4OD, 3.55, TS 6 chip, RiffRaff air filter.
Whoknows is offline
post #3 of 4 (permalink) Old 06-21-2018, 01:02 PM
Is your brake warning light on the dash on?
Have you checked the vacuum switch? If not, unplug it and try that.
Have you checked the parking brake switch?
Is your third brake light working? If you changed to LED, you need to add a resistor.
And last, pull the steering wheel and check the 3 spring contacts.
I have been through all of this. Mine had a bad vacuum switch AND one of the contacts behind the wheel was loose. It would loose contact when I turned the steering wheel.
97 F350 XL std cab, zf5, srw (converted), 4wd, 3.55s, stock wheels/tires & rebuilt 9.19
2 Donaldsons, 3" dp, ACs, T500, HV LPOP, Hydra w/PHP, DIY 60 gl tank w/6 gl sump, eFuel/Cat filters, Aeromotive RR, Auber instruments, 140v IDM, KC 300X 63/70/84, RiffRaff bellowed up pipes, 6.0 IC, 3" plenums w/RiffRaff inserts & SB 425HD
MeTo is offline
post #4 of 4 (permalink) Old 06-21-2018, 02:50 PM
Because I can!!!
Thatchevyguy's Avatar
If you have access to a scanner hook that up then you can tell what's really going on
97 F350 cclb
7.3 5spd
95 f350 rclb 7.3
02 f350 ccsb 7.3
Thatchevyguy is offline
