Cracked Cup/Nozzle/??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 03-17-2010, 08:55 PM Thread Starter
GM Duraturd's Avatar
Im not to good at diagnostics. My truck "pops" at idle and smoke white pretty bad. It is only heard from the exhaust, not really when your up by th motor, although it is pretty loud out of the exhuast. It only happens at idle, any other time drives and performs great. After idleing at a stop sign for a second, it will misfire for a split second when taking off and then drive normal. The smoke smells like raw fuel to me. Matt Popiel said he smelled coolant, but everyone else said just fuel.
I am thinking either a cracked injector cup, bad nozzle (could be spraying wrong and then once pressure builds up at higher than idle rpms it sprays ok?). Any help is appreciated.
http://www.youtube.com/user/cob32187.../0/a268gLzmGJ0
Also if a mod could embed the video for me it would be cool.
TOTALLED 1995 F-250
ISSPro, Grand Rock, DPP, DLC Diesel Performance, Total Diesel Performance, ATS, and a tired TTB.
1997 F-250
Precision Industries, Full Force Diesel, Beans Diesel Performance, DLC Diesel Performance, Banks Power, Aeromotive, Terminator Engineering, Gearhead Automotive, SuperLift, Bilstein, and a Dana 60
GM Duraturd is offline
post #2 of 12 (permalink) Old 03-17-2010, 11:39 PM Thread Starter
Re: Cracked Cup/Nozzle/???
bump.....
TOTALLED 1995 F-250
1997 F-250
post #3 of 12 (permalink) Old 03-18-2010, 12:45 AM
oilfield trucker
zpilgeram's Avatar
It almost sounds like an injector popped out a little. I had similar sypmtoms with my truck awhile back. Mine got progressivly worse pretty fast though.
96cc,lb,4x4,zf5. DIY dual filter intake, intercooled,gauges,4''down pipe, DIY front bumper/grill guard,fuel tank mod, 238cc Rosewood Diesel hybrids,6pos chip from TDP,
stealth SRP1 HPOP,Garrett GT4294 with DIY mounting kit,valair 500hp kevlar/ceramic clutch,Dual SD pumps electric fuel system with regulated return,5'' DIY Straight pipe.
zpilgeram is offline
post #4 of 12 (permalink) Old 03-18-2010, 01:52 AM Thread Starter
Mine has stayed about the same. I dont put to many miles on the truck lately so I havent driven it alot like that. I hope its something simple like that.
TOTALLED 1995 F-250
1997 F-250
post #5 of 12 (permalink) Old 03-18-2010, 03:29 AM
Patrick Feeley's Avatar
If you have a cracked injector cup, you should be seeing fuel in the coolant. Cheers!
Patrick Feeley is offline
post #6 of 12 (permalink) Old 03-18-2010, 03:33 AM
<---- Funny
wriott's Avatar
have you put it on a computer to see whats goin on... check to see what cyl is misfireing...
Will
2002 F-350 CC LB 4x4 DRW
3 other PSDs, Low-Pro Freightliner, and 12 other diesel trucks
Random pics
wriott is offline
post #7 of 12 (permalink) Old 03-18-2010, 03:53 AM Thread Starter
Which is not the case
No, I have not had a chance to get ahold of my buddies code reader. Also was gunna do a contribution test last week but the guy that owns the shop never called me back.
I dont drive the truck at all at college, it just sits at home. I have some time to figure it out since it doest get driven, just wanna know what to look for.
TOTALLED 1995 F-250
1997 F-250
post #8 of 12 (permalink) Old 03-19-2010, 04:53 PM Thread Starter
Any other sugestions? I know we got some good minds on here.
TOTALLED 1995 F-250
1997 F-250
post #9 of 12 (permalink) Old 03-20-2010, 03:40 AM
oilfield trucker
zpilgeram's Avatar
Is the popping steady or intermitten ? Is it rpm related ? Do you happen to hear anything if you put your ear on the air filter ? Kinda wondering if you don't have a slightly bent push rod.
post #10 of 12 (permalink) Old 03-21-2010, 04:12 AM
What else?
smokyred's Avatar
White smoke and a pop out the exhaust........have you checked for bent pushrods yet?
Dave
smokyred is offline
