Battery terminals always corroding - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
post #1 of 14 (permalink) Old 06-06-2018, 04:26 AM Thread Starter
Because I can!!!
Thatchevyguy's Avatar
so this has been an ongoing issue since ive had the truck. But about every month or two itll start cranking slower. Clean the terminals and good to go. Ive replaced countless clamps and this has been on 2 different sets of batteries. What causes this so bad? Anything i can do to fix it? I use a terminal grease that seems to help a little. This is more just annoying than anything. We have an old international 86 hydro thats pretty bad about corroding terminals as well but not quite this bad
97 F350 cclb
7.3 5spd
95 f350 rclb 7.3
02 f350 ccsb 7.3
Thatchevyguy is offline
post #2 of 14 (permalink) Old 06-06-2018, 04:45 AM
Master BS'er
jamiesaun's Avatar
Re: Battery terminals always corroding
Youre filling the batteries with water yourself, aren't you?
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #3 of 14 (permalink) Old 06-06-2018, 05:03 AM Thread Starter
Because I can!!!
Ive never had to fill either set that have been in the truck. Also first set of batteries were interstates and now is john deeres
97 F350 cclb
7.3 5spd
95 f350 rclb 7.3
02 f350 ccsb 7.3
post #4 of 14 (permalink) Old 06-06-2018, 05:17 AM
Master BS'er
jamiesaun's Avatar
Okay, interesting. Did you put a big alternator on the truck?
Sent from my SM-G950U using Tapatalk
Brother James
post #5 of 14 (permalink) Old 06-06-2018, 01:23 PM
BigRed02
BigRed02's Avatar
Have you tried dielectric grease??
Sent from my iPhone using Tapatalk Pro
2000 F350 CCLB 4x4 7.3L, 4R100, 6637, 4" MBRP turbo back
2000 F250 Red 4x4 Ext. Cab, 7.3L DI, ZF-6
2005 Ranger Dark Gray, FX4, 4 dr, 4.0 SOHC, 5r55e
2015 Ford Transit 3500, Dark Gray, HR EX, 3.5L ecoboost, 6 speed select shift
2011 Edge Limited Black, 3.5L
BigRed02 is offline
post #6 of 14 (permalink) Old 06-06-2018, 01:53 PM
79jasper's Avatar
Alt could be boiling them, but I would think you would be low on liquid in there.
I would peel back the insulation on the cables. Likely to have corrosion in there.
Also, use a baking soda/water mixture to clean everything.
79jasper is offline
post #7 of 14 (permalink) Old 06-06-2018, 02:02 PM
410customs's Avatar
crappy battery quality?
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
post #8 of 14 (permalink) Old 06-06-2018, 02:31 PM Thread Starter
Because I can!!!
Factory alternator
Ive tried several brands of terminal sealer and terminal grease. I've even used just regular grease as a neighbor recommended that.
I took off a little bit when I put all new ends on one time and there was a little bit but i cleaned that out
Nope only use good batteries here. Interstates were in it befoee and theybare normally very good and John Deeres in it now, and they are thebest we have found. We've probably got 10 sets of jd batteries around currently and the only ones we have issues with are in my 97 and that 86 hydro and they do it no matter what battery
97 F350 cclb
7.3 5spd
95 f350 rclb 7.3
02 f350 ccsb 7.3
post #9 of 14 (permalink) Old 06-06-2018, 03:09 PM
Master BS'er
jamiesaun's Avatar
Well check the voltage at the battery while it's running. It's either over filled or over charging.
Thatchevyguy likes this.
Brother James
post #10 of 14 (permalink) Old 06-06-2018, 05:25 PM
Bugman's Avatar
I have never had much luck with aftermarket battery terminals.
Perhaps it is just time for new cables.
BigRed02 likes this.
Bugman is offline
