Just bought a truck -- no start, no smoke - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 03-16-2010, 10:19 PM Thread Starter
Hello, I am new to diesels but not to diagnostics or mechanical work. I just bought a 95 5sp 4x4. I got it cheap because it was only running on 6 cylinders and drove it 80 miles to where it is stored now.
The common injector power wire was loose in the drivers side rear connector which explains why it was running on 6. I then (as preventative maintence)replaced the batteries, cleaned battery connectors, replaced glow plugs, UVCH's, and gaskets as well as replaced the offending connector.
Now the truck will not start at all --> cranks, tach moves, no smoke, 60 lbs of fuel pressure at the test port.
I checked the resistance across each injector (at the valve cover connectors) and they are all within 0.1 ohms (about 2.7). I also checked the resistance of the glow plugs through the connectors and they were all about 0.8 ohms. I also double checked to make sure I didn't bump anything.
My question is how do you guys check for injector pulse? I normally would use a noid light or LED logic probe (on a normal gas engine)but with 100V signaling the injectors this would not be appropriate.
I would also like some input on a good scan tool to buy for this application. I do have alot of experience with the OTC Genisys, NGS, Snap-on red brick and SOLUS.
And of course some helpful hints and suggestions for dianosis would be appreciated as well.
Thank you, first time poster long time lurker.
SS496 is offline
post #2 of 27 (permalink) Old 03-16-2010, 10:42 PM
JFURNER77
JFURNER77's Avatar
Re: Just bought a truck -- no start, no smoke
You need to see if the IDM relay is power on, or if it is grounding out. If there is shorts in main engine harness, PCM will shut off IDM relay and no power to IDM, no pulse to injector soilenoids.
Do you have "WTS" lamp? I would check the G.P. relay w/ volt meter to makes sure it is receiving proper signals.
Also need to check HPOP system. Even with IDM pulse, injector still needs high pressure oil.
1997 F350 4X4 XLT CREW CAB
7.3L POWERSTOKE DIESEL 390,000
T/S 6 POS CHIP, STAGE 1'S, 17* HPOP
6637 AIR INTAKE/NO CAT
4R100 STAGE 3- 12" TRIPLE DISC BILLET TORQ, BILLET INPUT, RED ALTO'S, TUGGER KIT, CUSTOM VALVE BODY, DERALE TURBO PAN.
5" SUSPENSION LIFT, STAINLESS NERF-BARS
16X10 PRO COMP 35X12.50 TOYO OPEN COUNTRY A/T II
JFURNER77 is offline
post #3 of 27 (permalink) Old 03-16-2010, 11:19 PM
foxracing0934's Avatar
Send a message via AIM to foxracing0934
Sounds stupid but did you check the fuse block under the hood? I think it's fuse 19 that powers the IDM.
Richard
97 F-350 PSD
6637, Rosewood Stage II's, DP-Tuner, modded 17*, ARP studs, 5" stacks and a bunch of other misc. stuff.
foxracing0934 is offline
post #4 of 27 (permalink) Old 03-16-2010, 11:37 PM Thread Starter
I will double check the fuse tomorrow.
I do have the wait so start light coming on and off; I also shorted a screwdriver across the GP relay before attempting so start it just to double check.
How can I check the ICP sensor with out a scan tool. I know the pressure should be at least 500-600 psi while cranking. I have a mechanical gauge that goes to 6000 psi (I would just need to get fitting adapters); that will obviously check the out put of the pump.
Anyone know what the voltage at the ICP sensor should be at 500-600 psi?
Thanks
SS496 is offline
post #5 of 27 (permalink) Old 03-16-2010, 11:53 PM
JFURNER77
JFURNER77's Avatar
500-600 psi. 1 volt, 2500 psi. 3 volt
You want to make sure G.P. relay is turning ON and OFF. A constant voltage feed through harness will cause major problems.
IDM relay fuse can be good and PCM can still ground out the IDM relay.
post #6 of 27 (permalink) Old 03-17-2010, 12:29 AM
I know nothing...
joedaddy's Avatar
Hope you get'er figured out, to PSN
Doesn't roll with anyone or tag along to be cool...
joedaddy is offline
post #7 of 27 (permalink) Old 03-17-2010, 09:07 AM
Check the oil in the HPOP it may have leaked down in storage.Check the tin nut on the IPR to verify its tight.
97 F250 4WD, SC,5sp,4.10, D60, Guages,Tymar intake,EBPV Gut,round downpipe,SBC Con-O,Stancor
87 Tbird TC 5sp
87 Tbird TC Auto
clem is offline
post #8 of 27 (permalink) Old 03-17-2010, 11:44 AM
The Fireman's Avatar
You should be able to unplug the ICP sensor and it would run anyways. Unplug it and try to start, if it runs that is your culprit. What the previous posters said also.
Bryan
97 F250 SC LB 4x4 Auto 368,000 miles, AD's, 3in down pipe, Straight Pipe,EBPV deleted, DIY Intake, Racer X converter and valve body, Beans tunes
The Fireman is offline
post #9 of 27 (permalink) Old 03-17-2010, 07:02 PM Thread Starter
I will check the suggestions when I get a chance.
Another weird thing is the CEL only blicks once when the key is turned on.
SS496 is offline
post #10 of 27 (permalink) Old 03-17-2010, 09:02 PM Thread Starter
Any body have a schematic of the engine harness and IDM relay so I can check these pieces?
SS496 is offline
