icp voltage low - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 03-16-2010, 10:11 PM Thread Starter
mouse4x4's Avatar
icp voltage low
Well I replaced the ice sensor still reading low voltage while driving like .5 volts wide open throttle check engine comes on my connector has some corrosion could that be it. If so can u get new pig tails if yes where.
96 350 LB CC 4x4, 5 speed, 4 inch all spring lift, 35 mt, 18 inch classic 2, beans stage 1 injectors, beans custom tunes, 3in down pipe 4in mbrp exhaust, cold air intake, idm modd 220,000
05 QC 3500 SB Cummins, 5 inch moto blue, afe intake, daddy built trans, magtec DD, 4.10 gears, edge juice with tude, 120,000
mouse4x4 is offline
post #2 of 3 (permalink) Old 03-16-2010, 10:57 PM
JFURNER77
JFURNER77's Avatar
Re: icp voltage low
I would ohm the ICP connector back to PCM plug. Check for high resistence in the wire, and breaks in continuity at the ICP connector. I will check some old harness's that I have for a good ICP plug.
1997 F350 4X4 XLT CREW CAB
7.3L POWERSTOKE DIESEL 390,000
T/S 6 POS CHIP, STAGE 1'S, 17* HPOP
6637 AIR INTAKE/NO CAT
4R100 STAGE 3- 12" TRIPLE DISC BILLET TORQ, BILLET INPUT, RED ALTO'S, TUGGER KIT, CUSTOM VALVE BODY, DERALE TURBO PAN.
5" SUSPENSION LIFT, STAINLESS NERF-BARS
16X10 PRO COMP 35X12.50 TOYO OPEN COUNTRY A/T II
JFURNER77 is offline
post #3 of 3 (permalink) Old 03-17-2010, 08:04 PM Thread Starter
mouse4x4's Avatar
Re: icp voltage low
Thanks a lot I will try that out. I need to replace my ipr connector the wire is squishy feeling don't know if from heat or oil soaked it would be great if you have those connectors let me know
mouse4x4 is offline
