Are these numbers acceptable - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 05-31-2018, 05:24 AM Thread Starter
College Student
Over last weekend, I was towing a 16' horse trailer loaded down 6k lbs or so. My rolling weight was little over 17 thousand if I remember right when I stopped at a weight scale just to see how heavy I was.
Nothing really out of the normal from what I do in central Idaho. I had the torque pro app going and just want to see if these numbers are normal or high or low of what they are supposed to be for certain parameters.
Truck is 7.3 with 247k, baby swamps injectors with their tunes on a TS6. 4EOD. 4.10 gears going about 35-55mph climbing decent hills. Never let the exhaust temps over 1150 degrees and backed out of it when it got close and shifted down. Non intercooled. I was running swamps towing tune which I guess is supposed to be around 75hp increase.
Flat ground-
Volts: 13.3
Turbo: 1-4 psi
Oil temp: 210-215
Tranny: 180
EBP: 16-17psi
HPOP: 2,500psi
IPR: 36-38%
Climbing hills-
Volts: 13.3
Turbo: 7-12 psi
Oil temp: 215-225
Tranny: 185
EBP: 16-18 psi, then 38-42 psi with exhaust break on.
HPOP: 2600 psi
IPR: 38-45%
Just curious to what others readings are...
95 Auto. 4.10 gears. SCLB. Stock besides Baby Swamps Injectors and TS-6 chip with swamps tunes. AFE MaxFlow. Glowshift trans, pyro, and boost. 6.0 IC KC TP38R. Converted EBPV to exhaust brake.
Cumminsdurastroke is offline
post #2 of 2 (permalink) Old 06-06-2018, 10:11 PM
GeneralTragg's Avatar
That all looks pretty average to me. Mine is around the same #s with torque app with no tunes as far as I know
GeneralTragg is offline
