Fluctuating idle when hot - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 60 (permalink) Old 05-31-2018, 01:33 AM Thread Starter
Project Shamu
Lt.Dan's Avatar
Alright guys, I’ve posted about this before, but it’s still bugging me and I want to start a fresh thread to see if I can get some of your minds moving.
So this started when I put my motor back together and installed it in the truck. I had it completely rebuilt top to bottom, bored .020” over, full ford overhaul kit etc etc.
Now when the truck gets hot, the truck gets a little shakey and the idle will fluctuate up and down a bit. It will do it randomly too, never rhythmic or anything. The hotter it is, the worse it gets. It’s not super bad where I think it’s going to stall or anything but an annoying shake. When cold, the truck runs as smooth as any ‘17 6.7 I’ve ever seen.
With the scanner plugged in, IPR% is always a constant 6.5% to 7%, but exactly when the idle fluctuates, ICP value will go from a steady 425 to 500-525, then back down.
So, what’s the first step any of you would do to diagnose this. I’ve already done a lot, but I want to start from the beginning.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is offline
post #2 of 60 (permalink) Old 05-31-2018, 03:31 AM
79jasper's Avatar
Re: Fluctuating idle when hot
Not running junk T6 are you?
79jasper is offline
post #3 of 60 (permalink) Old 05-31-2018, 03:53 AM Thread Starter
Project Shamu
Lt.Dan's Avatar
Nope, Swamps tunes on a Hydra.
Lt.Dan is offline
post #4 of 60 (permalink) Old 05-31-2018, 04:29 AM
​ DieselDC's Avatar
First of all, I don’t like them #
Is like to see 12+ ipr and 500+ icp.
You have bad idle b/c of your tunes even if from swamps. My tunes sucked (__!__) - the ones I got from Corey with my hydra. All none of his fault b/c he gave them to me free with the hydra. So I can’t complain there. Couldn’t idle worth chit and I couldn’t figure it out. Got custom tunes and guess what? Crappy idle went away. Guess what was the difference? Ipr and icp was raised up a notch.
You’re mileage may vary and I hope it’s just as simple as that.
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
​ DieselDC is offline
post #5 of 60 (permalink) Old 05-31-2018, 05:11 AM Thread Starter
Project Shamu
Lt.Dan's Avatar
I wonder if the stock PHP tunes are any different? I've been wanting to hit up Jelich and get some tunes, maybe i'll try and bum a single one off him and see if it fixes it.
Lt.Dan is offline
post #6 of 60 (permalink) Old 05-31-2018, 05:15 AM
​ DieselDC's Avatar
If you got 160/30 you can try mine to see if it cures the idle. If it does then go get new custom tunes to better fit your truck.
—————signature—————
post #7 of 60 (permalink) Old 05-31-2018, 05:18 AM Thread Starter
Project Shamu
Lt.Dan's Avatar
—————signature—————
Unfortunately I don't, I have stock AB injectors. It shouldn't be too hard for someone to slap a tune together for me.
Lt.Dan is offline
post #8 of 60 (permalink) Old 05-31-2018, 11:02 AM
PSN intsigator
heavydoc's Avatar
I'm using the "community" tunes from hydra in my 96 and 02 and have no problems yet. 96 been in for 4 years and 02 only a few months. Waiting do do upgrades before I get custom tuning.
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is offline
post #9 of 60 (permalink) Old 05-31-2018, 01:06 PM
Moderator
Sbluke55's Avatar
It would be easy to use some php tunes to see if it fixed you issue. Also try and unplug your icp when it does it
01 f-250, Standard
Sbluke55 is offline
post #10 of 60 (permalink) Old 05-31-2018, 02:16 PM Thread Starter
Project Shamu
Lt.Dan's Avatar
Well I tried to drive to work in the PHP 65DD tune, and when i got to work, it wasn't shaking at all, but even when switching back to my Swamps tunes, the idle didn't start to fluctuate, I think I didn't get it hot enough (even though oil temp was over 200*). I'll try around lunch time and see what I come up with.
Lt.Dan is offline
