Misfire and shaking? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 05-28-2018, 12:54 AM Thread Starter
CDavis90's Avatar
Garage
It dose not matter cold or hot but its more noticeable at low rpm's. The engine feels like its misfiring and it shakes the truck a bit. I have replaced the ICP and rebuilt the IPR. While digging around i found a metal pipe similar to a break line that was shaped like a J and had short rubber hose on one end. I have no idea where that came from and could not seem to find where it came from it was just sitting there under the fuel bowl. The injectors are only a few months old and last year i replaced both Valve cover wiring harnesses and all glow plugs with the relay. I checked all the connections they seem tight and have electric grease on them. The truck also has a new ts6 chip that was installed at the same time as the injectors. This truck is a 97 f350 with an e fuel setup. Im not really sure where to go from here to figure this out. That little mystery pipe is a bit concerning i was thinking maybe is a vacuum line.
CDavis90 is offline
post #2 of 14 (permalink) Old 05-28-2018, 11:33 AM
alleged moderator
tjctransport's Avatar
Re: Misfire and shaking?
probably the fuel bowl drain.
there are no vacuum lines on a diesel engine. vacuum to operate the heat and ac controls come from the vacuum pump.
tom
tjctransport is offline
post #3 of 14 (permalink) Old 05-28-2018, 10:26 PM
Patrick Feeley's Avatar
Does it do it with the chip physically removed? Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3Ē DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is online now
post #4 of 14 (permalink) Old 05-29-2018, 03:27 AM
OBS__Stroker's Avatar
Pulled the oil cap while its running? If it has major blowby id suspect broken piston
OBS__Stroker is offline
post #5 of 14 (permalink) Old 05-30-2018, 02:15 AM Thread Starter
CDavis90's Avatar
Garage
Pulled the chip and just around the block its still doing it. I will be able to do a longer test on the way to work in the morning.
CDavis90 is offline
post #6 of 14 (permalink) Old 05-30-2018, 02:18 AM Thread Starter
CDavis90's Avatar
Garage
Wouldn't that have like a violent shaking? This is mild and pretty much unnoticeable above 1200. The symptoms during driving i noticed while the chip was in. in stock mode it felt like i had no turbo and was bulling 10 tons. back to the +75hp it would be doggy then it was like all the sudden the turbo would kick in and the truck almost drove normal after that. It will only do that once in the morning.
CDavis90 is offline
post #7 of 14 (permalink) Old 05-30-2018, 12:35 PM
alleged moderator
when it does it does it sound like a jet engine out of the exhaust?
the exhaust back pressure valve may be hanging partially closed.
my 02 used to do that until i bypassed the EBPV
tom
post #8 of 14 (permalink) Old 05-30-2018, 02:18 PM
410customs's Avatar
Make sure your EBPV is not sticking as TJCtransport pointed out
The factory pedestal is problematic especially when you get to higher miles
Also is the fuel bowl clean? clear green diesel fuel? Or is it black?
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
post #9 of 14 (permalink) Old 05-30-2018, 02:28 PM Thread Starter
CDavis90's Avatar
Garage
I will look into it i am getting codes for back pressure and cps even with new sensors.
CDavis90 is offline
post #10 of 14 (permalink) Old 05-30-2018, 02:29 PM Thread Starter
CDavis90's Avatar
Garage
Fuel is clean i just replaced the filter as well it had a bit of grey sludge on it.
CDavis90 is offline
