96 350 died while driving, #22 maxi fuse blown - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 05-27-2018, 04:18 AM Thread Starter
After it died wts light doesn't come on. New fuse didn't fix it. I've been searching but all results are about no starts from go relay, not about dying while running.
CatfoshGa is offline
post #2 of 10 (permalink) Old 05-27-2018, 04:21 AM Thread Starter
*gp relay
post #3 of 10 (permalink) Old 05-27-2018, 04:39 AM
Bugman's Avatar
Re: 96 350 died while driving, #22 maxi fuse blown
Unplug the fuel bowl heater off of the filter housing. It is the middle connector and you might need to use a screwdriver to get it off. Then just tape up the end and don't worry about it.
Bugman is offline
post #4 of 10 (permalink) Old 05-27-2018, 06:31 AM Thread Starter
That didn't fix it. Where to next?
post #5 of 10 (permalink) Old 05-27-2018, 03:50 PM
Bugman's Avatar
If that didn't fix it then you are going to have to start tracing wiring to find where it is shorting out at. That fuse only controls a few things and here they are: Fuel Line Heater, 215 Amp Generator/Voltage Regulator, PCM Power Relay Coil, Glow Plug relay
Bugman is offline
post #6 of 10 (permalink) Old 05-27-2018, 06:15 PM
Bugman's Avatar
Just as a fyi here is the location of the fuel heater connector on the filter housing.
Bugman is offline
post #7 of 10 (permalink) Old 05-30-2018, 04:53 AM Thread Starter
Updating, the #22 fuse was already blown when I pulled the connector to the fuel heater, must have blown as soon as I put it in.
I bridged the fuse connectors. Still no wts light.
Gp relay clicks when bridged.
Pcm relay tested good with the horn test.
I've inspected all the wires I can see before I pull the underhood fuse panel out and look under it and don't see any shorting.
I assume by shorting you mean a wire with insulation worn through that can touch metal?
Will a bad pcm pop this fuse?
post #8 of 10 (permalink) Old 05-30-2018, 12:23 PM
Moderator
Sbluke55's Avatar
Try unhooking the gpr. Also for grins. Unplug the icp and the ebps and inspect the ipr wiring
01 f-250, Standard
Sbluke55 is offline
post #9 of 10 (permalink) Old 06-02-2018, 07:25 PM Thread Starter
Heater wire chaffed under the fuel lines
post #10 of 10 (permalink) Old 06-09-2018, 05:32 PM
Thank you for the picture bugman as the labeling helps me get acquainted with these engines.
Thank you for posting back to let us know what the problem was CatfoshGa
Grassfed is offline
