Bolt size for shifter - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 03-16-2010, 02:37 AM Thread Starter
I bought my 97 project and it had the shifter laying on the floor and no bolts to bolt it back into the transmission. My question is does anybody know the size and thread pitch of these bolts? thanks.
birddog55 is offline
post #2 of 2 (permalink) Old 03-16-2010, 04:13 AM
Patrick Feeley's Avatar
Re: Bolt size for shifter
Are you refering to the shifter stub-to-shifter bolts? Or the 4 allen head bolts that secure the shifter pivot cover? The stub-to-shifter bolts (and I'm totally guessing here) are probably 8mm x 1.25. If it's the other ones I may be able to find that. Cheers!
Patrick Feeley is offline
