ProVent 200 Questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 05-26-2018, 01:48 AM Thread Starter
Diabolic1's Avatar
If I install one of these, do I need to route the hose up over the brake booster for a frame mount install or is straight downhill ok?
1997 CCSB, 7.3/E4OD
KC TP38R, CNC Fab Bellowed Up-Pipes, Full Force Stg 1 injectors, 3" DP, 4" exhaust, CNC Fab HPOP, Mark F E-Fuel, 7.3 Intercooler, 1.0 Exhaust Housing, TS Chip, remote coolant filter, and VB.
Diabolic1 is offline
post #2 of 7 (permalink) Old 05-26-2018, 02:40 AM
79jasper's Avatar
Re: ProVent 200 Questions
Why do you want to run it over the booster?
79jasper is offline
post #3 of 7 (permalink) Old 05-26-2018, 03:50 AM Thread Starter
Diabolic1's Avatar
So that a majority of its contents are just vapor, and the residue contained in the vapor.
1997 CCSB, 7.3/E4OD
post #4 of 7 (permalink) Old 05-26-2018, 03:52 AM Thread Starter
Diabolic1's Avatar
Like an inverted air gap or p- trap. Hoping the bulk of the oil would drain back into the vc.
1997 CCSB, 7.3/E4OD
post #5 of 7 (permalink) Old 05-26-2018, 08:03 AM
79jasper's Avatar
I see. If mounting it closer to the engine, you shouldn't need to do that. But of course the further you get from the engine, it'll be cooler and have more drop out before it even reaches the filter.
79jasper is offline
post #6 of 7 (permalink) Old 05-26-2018, 01:16 PM
'Cody''s Avatar
Either way is fine. Mine is mounted on the frame next to my e fuel. I did not run the hose up and over the booster. Just make sure there are no low spots and your golden.
Old Blue, 97' F350, CCLB, 7.3, Auto
Air: SD IC, 3" Plenums
Fuel: E- Fuel, 160/30 Injectors
Turbo: Irate T4, S366
Oil: T500, Melling LPOP
PCM: TW TS, IDM Mod
'Cody' is offline
post #7 of 7 (permalink) Old 05-26-2018, 07:43 PM
​ DieselDC's Avatar
Hang it down and have a catch can. I took mine off. Worked well when I had.
Now I just have a hose with a bend. Hopefully it has more vapor than oil. Hate the oil making all my boots and cac oily.
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
​ DieselDC is offline
