Glow plugs and rocker arm question 7.3 DIT - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 05-23-2018, 02:24 AM Thread Starter
Question: While replacing my glow plugs about a week ago I did not first soak up the oil around the glow plug, so some oil will have dripped into the combustion chamber. Will this be a over pressure problem in the combustion chamber and by the time I try to crank it probably 10 days or more will have gone by? Also, I checked the torque on the the 4 rocker arm pedestal bolts for each cylinder at 20 ft-lbs, and then noticed a 5th 8 mm bolt just below the injectors between the valve springs. Is this 5th 8 mm bolt a rocker arm bolt and what should it be torqued to? Thanks for your expert advise!
1997 F350 4x4
Luv2bike
Jeff
Luv2bike is offline
post #2 of 5 (permalink) Old 05-23-2018, 02:32 AM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Re: Glow plugs and rocker arm question 7.3 DIT
The oil won't be an issue. That 8mm bolt is one of the injector hold-down bolts.
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
post #3 of 5 (permalink) Old 05-23-2018, 09:48 AM
Terminator Nation
The injector holddown bolts should be torqued to 120 INCH-lbs. Old service manuals used to spec 105 but the value has been changed.
Crank the engine over by HAND a couple of times to make sure its not hydrolocked. If it turns over then its OK.
old man dave is offline
post #4 of 5 (permalink) Old 05-23-2018, 09:34 PM Thread Starter
Thanks Cummins Junkie!
Luv2bike is offline
post #5 of 5 (permalink) Old 05-23-2018, 09:35 PM Thread Starter
Thank you Dave, got it!
Luv2bike is offline
