Parking Brake and ABS - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 29 (permalink) Old 03-15-2010, 10:14 PM Thread Starter
The Original
BigStroker's Avatar
Dumb question but what is causing my park brake light and my ABS light to be on in the truck?
The only thing I can think of is the ABS sensor in the rear.
The park brake light is what has got me thrown here
Edit: It hasn't effected braking or anything else on the truck.
[CENTER]1994 F350 4x4 5spd, 1995 F250 4x4 5spd, 1996 F250 4x2 auto, 1997 F350 4x4 auto, 1997 F250 4x2 auto
#27
BigStroker is offline
post #2 of 29 (permalink) Old 03-15-2010, 10:37 PM
Re: Parking Brake and ABS
That isn't (just) the "Park brake" light. It's primarily the brake FAILURE WARNING light. That it lights up with the parking brake is the least important of its uses. Much more importantly, it lights up when (1) there's a hydraulic failure (e.g. leak), there's a vacuum failure leading to no power boost, and (3) there's an ABS failure.
Your issue is most likely the third, but for good measure, you should check the hydraulics and confirm no leaks.
Does the speedometer work as expected? What about cruise control?
madpogue is offline
post #3 of 29 (permalink) Old 03-15-2010, 10:42 PM
Offical Puddle Displacer
pstroke96's Avatar
Send a message via AIM to pstroke96
my truck had a bad brake line on it. both lights were on because of it
Refugee
pstroke96 is offline
post #4 of 29 (permalink) Old 03-15-2010, 10:46 PM Thread Starter
The Original
BigStroker's Avatar
Everything works fine no leaks nada.
Lights just decided to come on the other day.
#27
post #5 of 29 (permalink) Old 03-15-2010, 11:13 PM
The only thing I have ever seen cause both lights to come on is it sensing low fluid. Wiggle the connector for the level sensor or pull it out and clean it. Usually you have to replace the bottle but I've gotten it to work sometimes by just cleaning the connection. Hope this helps.
It's NOT your abs or the rear speed sensor. Those can't trip both lights unless something else is wrong too.
rrranch is offline
post #6 of 29 (permalink) Old 03-16-2010, 01:26 AM
Demon Dually
speeddemon31176's Avatar
The VSS/ABS sensor in the rear axle will cause both lights to come on if it is faulty or dirty. Try cleaning it first then if that doesn't fix it replace it and the lights will go out.
speeddemon31176 is offline
post #7 of 29 (permalink) Old 03-16-2010, 01:47 AM
02 CCSB
The sensor in the rear axle will cause the ABS light and ONLY the ABS light to come on. Mine was broken off and no brake light, check the level in the resivoir.
02 CCSB Lariat F-250, Auto, 3.73, 6", 35" Toyo OC MT, Juice w/Attitude, 4" Turbo back MBRP, owner built trans, billet triple disc, 31 row 6.0 cooler, tugger and aux filter, Snow tow max
94 RCLB XLT F-150, 5.0 5spd, 4.10 Tru Trac, 4", 33" BFG AT
02 CCSB is offline
post #8 of 29 (permalink) Old 03-16-2010, 02:09 PM Thread Starter
The Original
BigStroker's Avatar
Cool thanks guys.
PS cruise doesn't work
#27
post #9 of 29 (permalink) Old 03-16-2010, 03:04 PM
bobvillaoftn's Avatar
did you do the recall for the cruise thing that came out end of last year? if not that could be your problem.
05 f350 CCLB 4x4 delete and sct x4 thanks to innovative
Originally Posted by RedSmokey View Post
Sh*t in a box (litterally) and write "Will give you 200+ hp, just add to your fuel" on the box and give it to him. Then ask him if he still believe's everything thats written on a box...
Originally Posted by bruce51d View Post
if you can blow up a 7.3 just imagaine what you would do to a 6.0
bobvillaoftn is offline
post #10 of 29 (permalink) Old 03-16-2010, 03:06 PM Thread Starter
The Original
BigStroker's Avatar
Nope I didn't
#27
