Low Power, Low Boost & No Timing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 05-20-2018, 03:46 AM Thread Starter
Unhappy Low Power, Low Boost & No Timing
I have a 97 F250 HD with the 7.3 and auto trans. Went to pick up our new 5th wheel camper today and the truck seemed to be pretty much dead in terms of power. Boost was topping out at about 6 psi (normally could get 12 without towing anything. Last fall pulling our old camper, Gross weight just shy of 19,000# it pulled great even up the mountains in Va. and Tn, boost maxed out about 13 or 14. Fuel psi is good and EGT's seem a little low but there's no good pulls in South Jersey. Started going through the readings in my Edge programmer and came up with a reading of 0 for the timing and did not change at all. other readings seem ok.
Is there a default mode that it would go into if there is a problem? Mods are rebuilt stock turbo and EBPV New up pipes from exhaust to turbo, 3" down pipe with 4" straight through exhaust. I also have an Edge programmer currently set to race mode and an aftermarket inter-cooler system. Seemed to be running ok prior to going to pickup the camper today but haven't really been into the throttle just going back and forth to work. The only other thing that has changed recently was the replacement of my alternator 2 days ago as the last one died.
jeffgut is offline
post #2 of 4 (permalink) Old 05-20-2018, 11:56 AM
alleged moderator
tjctransport's Avatar
Re: Low Power, Low Boost & No Timing
welcome to PSN.
first thing i would do is return it to stock tune and give it a try.
it sounds to me like there is an issue with the tuner, because the tuner is what sets the timing.
i am not a fan of edge products, i have heard way to many horrors stories to put one of their products in anything i own.
tom
tjctransport is offline
post #3 of 4 (permalink) Old 05-21-2018, 09:30 AM Thread Starter
Originally Posted by tjctransport View Post
welcome to PSN.
Thanks. I'll give it a try and see what happens.
jeffgut is offline
post #4 of 4 (permalink) Old 05-22-2018, 02:01 AM Thread Starter
welcome to PSN.
Tried setting it back to stock and still low power and reading 0 timing. I'm thinking possible PCM problem?
jeffgut is offline
