97 F350 7.3 ZF5 2WD front end interchange info - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 05-17-2018, 03:26 PM Thread Starter
velocejoe's Avatar
Damaged my front right suspension/hub/steering/steering box. Going junkyard hunting. What parts interchange from what years? I need front hub assy, all steering linkages, the trac rod back to frame and the locater over to under engine, steering box.
I cannot find a diagram ANYWHERE listing all the parts, so I don't even know what they are called. Can someone help?
95 F350 OBS Dually, 2wd, LB, EC, 5SPD 310K!
New: Clutch, Fuel Pump. CCV MOD, FB Rebuilt, 3" DP, Tyler Performance Cold Air Intake, Rebuilt Oil Cooler, Used turbo just installed with 90K. 15.5 MPG pulling one-car trailer loaded.
Appears all original. Not even burning oil!!!
velocejoe is offline
post #2 of 2 (permalink) Old 05-17-2018, 03:50 PM Thread Starter
velocejoe's Avatar
Re: 97 F350 7.3 ZF5 2WD front end interchange info
OK, found parts diagram.
Need RT AXLE ARM, RT RADIUS ARM, RT KNUCKLE, RT HUB/ROTOR, RT CALIPER ASSY, RT RADIUS ARM MOUNT BRACKET.
From what I can tell most all parts are same for F150-F350 except Radius Arm which is specific to DRW.
Also, how do I know if I have SUPER COOLING on my 7.3? This determines which stabilizar bar to use.
