Lope on start up even in neutral. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 05-14-2018, 01:38 AM Thread Starter
CDavis90's Avatar
Garage
So i can find youtube video's all over the place that are doing the same exact startup lope or rough idle that my truck dose on start up cold or hot. So if im in park or neutral i have this hard lope until i bring it to about 1000 rpm's for a few seconds and you can hear the engine recover from it then it will run fine. And even more recently my engine is more or less freaking out while im driving and will even stall out. Im thinking this part is due to my ICP "again" the code for this has come back several times so im gonna start with that. Symptoms are while driving the rpm's are jumping about 50-100 sporadically and the engine sound changes with it and some white smoke as well.
CDavis90 is offline
post #2 of 4 (permalink) Old 05-14-2018, 01:43 AM
PSN intsigator
heavydoc's Avatar
Re: Lope on start up even in neutral.
I think I would look at the cps, check fuel pressures, (high and low) and high pressure oil for leaks or low pressure
Sent from my SM-T670 using Tapatalk
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is offline
post #3 of 4 (permalink) Old 05-14-2018, 06:51 AM Thread Starter
CDavis90's Avatar
Garage
The cps has actually been changed twice the first time it was replaced by a shop while i was stranded they used a "good Used" one. later i replaced it with a motorcraft part.
CDavis90 is offline
post #4 of 4 (permalink) Old 05-15-2018, 03:20 AM Thread Starter
CDavis90's Avatar
Garage
So blown o ring on ICP. Most of the rpm jumping is under controll but now there is a shudder in the engine. New icp is on the way.
CDavis90 is offline
