97 7.3 rebuild questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By JCart
post #1 of 6 (permalink) Old 05-11-2018, 01:44 AM Thread Starter
I have low compression on this engine other then that still runs and drives great just blows white smoke on start up. Looking into rebuilding it myself or having it done. I got a quote from a shop for 6,000 for just the long block with Arp head studs but have also seen long blocks on U.S Engine Production inc. For 3500 for the long block. Has anyone used one of these? And if I do do it my selve what can I reuse stuff like the lifters and valves or is that not a good idea motor has 235xxx miles. Thanks
Mr.Stroker is offline
post #2 of 6 (permalink) Old 05-11-2018, 02:43 AM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Re: 97 7.3 rebuild questions
Have you actually compression tested the engine? White smoke on startup isn't hard evidence of low compression.
And you wouldnt need to reuse stuff like valves and lifters. Thats part of a "long block" package. You'd need to source your own injectors, hpop, turbo, up pipes, and stuff like that.
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
post #3 of 6 (permalink) Old 05-11-2018, 02:33 PM
410customs's Avatar
My guess is your 7.3 is just fine and likely needs some upgrades / new injectors and or turbo work
235K is barely broken in for a 7.3
and you said it runs great when warm, this does not = low compression
Grey smoke until wamr is usually oil getting past the injectors or through the turbo seals
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
post #4 of 6 (permalink) Old 05-11-2018, 04:13 PM
2000f250's Avatar
White gray smoke at start up could be oil gettin the cylinder warn injectors not spraying right or weak glow plugs. I would keep driving it.
2000f250 is offline
post #5 of 6 (permalink) Old 05-13-2018, 06:59 PM
White Grey smoke could also be a few glow plugs out.... (pending how many are out and how long the white smoke lasts). Id recommend plug it in for three hours and see if it smokes on start up.
j
tjctransport likes this.
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
post #6 of 6 (permalink) Old 05-14-2018, 05:56 AM Thread Starter
Sorry i should have been more clear everything up top is new and yes i ran a compression test
