Losing 1gallon of oil per day - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By Bugman
  • 1 Post By 410customs
post #1 of 3 (permalink) Old 05-10-2018, 02:25 PM Thread Starter
Recently my 97 7.3 had started using 1gallon of oil per day. It's not coming through the turbo andno visible leaks on the frame or ground. Fuel economy went up about 6-7 mpg at the same time so believe it's going back to my fuel tank.
I replaced all the injectors with rebuilt ones in October. I called company to get their opinion and the guy suggested it was probably either a clipped o ring on install or bad ipr sending to much.
Any thoughts on if these are more or less likely would be appreciated. Thanks
Andrew W is offline
post #2 of 3 (permalink) Old 05-10-2018, 02:28 PM
Bugman's Avatar
Re: Losing 1gallon of oil per day
Take a look at your fuel filter, I am willing to bet that it is black.
I am almost will to bet on a bad injector O ring.
Zmann likes this.
Bugman is offline
post #3 of 3 (permalink) Old 05-10-2018, 02:35 PM
410customs's Avatar
Bad O ring(s)
Zmann likes this.
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
