1997 7.3l overheating - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 05-07-2018, 09:11 PM Thread Starter
What’s up guys, I have a 1997 F350 7.3l and it’s starting to overheat and piss coolant out of the top of the reservoir. Before it was a milkshaky brown but I replaced the oil cooler and gaskets, replaced the radiator, and cleaned out the reservoir, got everything back together and she fired up, but after 5-10 minutes of driving the temperature gauge startes to get pretty high and it starts pissing coolant. Anybody have any ideas, thanks in advance.
-Wes
Obswes7.3 is offline
post #2 of 5 (permalink) Old 05-07-2018, 09:38 PM
Bugman's Avatar
Re: 1997 7.3l overheating
You might have a air lock in the radiator.
How much coolant did you put back into the system? Have you tried to run it for a while with the recovery tank cap off?
Bugman is online now
post #3 of 5 (permalink) Old 05-08-2018, 05:57 AM
Native Texan
masakimm's Avatar
Garage
Mine has done that there is a plug down on the water pump next to the thermostat. pop it open and should release the air lock.
"Y'all have a wonderful"
"My name is Bob the guy floating in the lake with no arms and no legs"
Bob W Martin 1948-2014 USAF
Upgrades:
masakimm is offline
post #4 of 5 (permalink) Old 05-08-2018, 02:59 PM
Wesley Stankiewicz Jr.'s Avatar
Where is the airlock at on the water pump exactly? I’m going to check it when I get off.
Wesley Stankiewicz Jr. is offline
post #5 of 5 (permalink) Old 05-08-2018, 03:05 PM
Native Texan
masakimm's Avatar
Garage
Originally Posted by Wesley Stankiewicz Jr. View Post
Where is the airlock at on the water pump exactly? Iím going to check it when I get off.
its a little plug with a 1/4 square drive in it I used 1/4 extension and ratchet to take it out.
Upgrades:
masakimm is offline
