WTS light only comes on for about 2 seconds - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By tjctransport
post #1 of 8 (permalink) Old 05-07-2018, 02:36 AM Thread Starter
KIB7.3's Avatar
Garage
I have a 96 F250 and the WTS only stays on for a second. I know the WTS light is just a basic indicator light and I know my GPR and glow plugs are working. Does anyone know what would cause the WTS light to illuminate for only 1-2 seconds. It doesn't matter if its 30 or 110 degrees outside. I was thinking about unplugging the light bulb and running a Glow plug LED in to the spot on the dash and have that as my new WTS light. What do you guys think?
XLT CCSB, 4x4, 3" Downpipe, 4" Exhaust (with CAT delete), 140V IDM Mod, TS6 Position Chip, K&N, Transmission built by State to state transmission in AZ
KIB7.3 is offline
post #2 of 8 (permalink) Old 05-07-2018, 02:50 AM
Bugman's Avatar
Re: WTS light only comes on for about 2 seconds
Why even worry about it as long as you know that your glow plug relay is working?
Just turn the key on and wait for a bit and then start the truck.
If everything is working properly the glow plugs will stay on for up to 2 minutes.
Bugman is offline
post #3 of 8 (permalink) Old 05-07-2018, 03:30 AM
79jasper's Avatar
I looked at the voltmeter more than the wts.
Not that I really watched either. Get in, turn key on, buckle up and whatever else I'm doing, then start.
79jasper is offline
post #4 of 8 (permalink) Old 05-07-2018, 04:00 AM Thread Starter
KIB7.3's Avatar
Garage
I understand, I guess its more for other people then me (AKA the wife). If someone jumps in my truck and see a "wait to start light" chances are they will wait. Not only that I kinda like the stock look and the GP LED will allow me to know my GP is working from in the cab.
KIB7.3 is offline
post #5 of 8 (permalink) Old 05-07-2018, 09:56 AM
alleged moderator
tjctransport's Avatar
i use a glow plug LED in all my diesels. hooked up to the output of the GPR.
KIB7.3 likes this.
tom
tjctransport is offline
post #6 of 8 (permalink) Old 05-08-2018, 01:32 AM Thread Starter
KIB7.3's Avatar
Garage
Right I want to do this anyways and I was thinking what would be better then to run it right in the stock WTS location.
KIB7.3 is offline
post #7 of 8 (permalink) Old 05-08-2018, 04:25 AM
Bugman's Avatar
To run it to the stock WTS light or position I would be willing to bet that you will have to deal with a PC board with all the other lights in that panel connected to it.
Bugman is offline
post #8 of 8 (permalink) Old 05-08-2018, 04:51 AM
79jasper's Avatar
Yup. And how ford did goofy things like controlling the ground side of things.....
But.... you could run new wires, block the contact strips, and be g2g.
79jasper is offline
