96 Reg cab 4x4 7.3 build... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 05-06-2018, 11:39 PM Thread Starter
About to start the build on my 96 Ford F-350 reg cab 4x4 Auto 7.3 PS.
Bought it from a guy that had engine issues. Said the engine block may have a crack in it. He just put new Cooper STT Pro 37x13.50x17 on it a month ago.
Right now if the block is cracked, my plan is to have a machine shop do all the machining of the other block I will be getting as well as rebuilding heads and full assembly up to a long block. All labor they said will be 2000 or little less. I will be purchasing the ford motorcraft overhaul kit, ford motorcraft reman HPOP and of course other odds and ends.
Planning to get some injectors that will be capable of 400hp and rebuild the turbo. I will also be adding a intercooler and possibly be doing a zf5 manual conversion.
File Type: jpg CC122597-F8EF-4F49-9CE4-B994D0E3D54C.jpg (219.0 KB, 7 views)
1996 FORD F350 REG. CAB 4X4 AUTO 7.3 POWERSTROKE WORK IN PROGRESS
10ac is offline
post #2 of 3 (permalink) Old 05-06-2018, 11:41 PM
PSN intsigator
heavydoc's Avatar
Re: 96 Reg cab 4x4 7.3 build...
Sounds like it will be a runner when you get it all done
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is offline
post #3 of 3 (permalink) Old 05-07-2018, 04:16 AM
KIB7.3's Avatar
Garage
Nice build! Any reason why you're going with a reman stock HPOP and not a T500 or Adrenalin?
XLT CCSB, 4x4, 3" Downpipe, 4" Exhaust (with CAT delete), 140V IDM Mod, TS6 Position Chip, K&N, Transmission built by State to state transmission in AZ
KIB7.3 is offline
