Fuel Pump - to replace or not replace? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 01-17-2008, 05:52 PM Thread Starter
Michael's Avatar
I have my fuel bowl off (as described in another thread). Should I replace my fuel pump while I have access to it? Money is rather tight right now (which makes me lean towards not fixing it if it ain't broke), but this thing does have 255,000 miles on it. How often do factory fuel pumps fail?
Thanks,
Michael Pliska
95 F350 CC DRW, ISSPRO Performax gauges, Diamond Eye 3x4" DP & 5" exh, MBRP tip, Baby Swamps & tunes, Trans VB mods, Dunrite TC, Lock-Right, Cal-Tracs
99 Silverado race truck
96 F250 RCLB, bone stock
00 Jetta TDI, Kerma Tunes, Der Chimera Stg 3 clutch
73 & 74 Vega race cars, 92 GMC Typhoon, 73 Chevy Blazer with Pontiac 400, 73 Trans-Am 455
Michael is offline
post #2 of 6 (permalink) Old 01-17-2008, 05:56 PM
6.4's are my Hero.
Reubine's Avatar
Send a message via AIM to Reubine
Re: Fuel Pump - to replace or not replace?
Some people put a new one on it, and a couple of months later it is out again. It would obviously be easier to change it now instead of later. But if it aint broke then there aint no reason to change it!! Good luck.
'95 Ford F-350, CC,4x4,SWAMPS 300/200Hybrids,H-11 Head studs,Comp 910 Springs,Chromemoly push rods,modded TE 17*, GARRETT GT40 TURBO,built trans with 3 disc billet convertor,SWAMPS 6 position chip,3"DP to 6" single, IDM Mod,Gauges,'02 SD IC,Electric Fuel system and bunch of other stuff.
Reubine is offline
post #3 of 6 (permalink) Old 01-17-2008, 06:23 PM
racehauler's Avatar
I have the stock fuel pump from my truck as well. 110,000 miles and I would bet that it's the stocker. It's priced much similar to the fuel bowl
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #4 of 6 (permalink) Old 01-18-2008, 02:00 AM
mandkole's Avatar
IMO, if its 255K on the original, you're rollin the dice--I'd change it. It's a lot easier to do it now and you can give the valley a thorough cleansing.... Baxter keeps the OE Carters in stock. Does ISSPRO have an account at Baxter? If not, I could save you a few bucks as we get dealer pricing. PM me if you want to set up a buy.
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
mandkole is offline
post #5 of 6 (permalink) Old 01-18-2008, 03:31 AM
racehauler's Avatar
I think Carter is the only manufacturer of the OBS fuel pump so it really doesn't matter where you buy it. The cheapest place is the best place.
Eric
96 F-350 CC Dually
post #6 of 6 (permalink) Old 01-18-2008, 03:48 AM
OEM Moderator
Tom S's Avatar
I would replace it.
Tom
Tom S is offline
