IPR question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-14-2010, 03:56 AM Thread Starter
misterfruehling
misterfruehling's Avatar
Send a message via MSN to misterfruehling
IPR question
wheres the ipr sensor located
1999 CB f350 dually
1995 STD f350 dually flatbed
misterfruehling is offline
post #2 of 7 (permalink) Old 03-14-2010, 04:25 AM
Re: IPR question
On the rear of the HPOP on the drivers side of it.
1997 F-250 PSD, 130k, 4x4, Outlaw E4ODX, Standard Cab, reg bed, 3.55 LS rear, Swamps 225/146 injectors, Autometer Guages Pyro/Boost/Tranny, 3" downpipe, 3.5" adjusted exhaust, ts 6 pos chip, Tonys fun programs, Tru-Cool H7B, 285/75, factory alum rims, Western V-Plow, 6.0 intercooler installed not plumbed
BlindViper is offline
post #3 of 7 (permalink) Old 03-14-2010, 04:44 AM
Patrick Feeley's Avatar
Re: IPR question
Since you mentioned sensor, your question can be taken a couple of ways, so maybe this will lessen any confusion (or maybe not depending on my attempt at an explanation):
The Injection Pressure Regulator (IPR) is a solenoid-controlled valve that is used to control the pressure in the High Pressure Oil system. It is on the rear of the HPOP as stated above
The Injection Control Pressure (ICP) sensor is the sensor that signals the truck's PCM what the pressure is in the HP Oil system so that the PCM can command the IPR valve how to regulate the HP oil pressure. It is on the front, top of the driver's side head coming out at about a 45 degree angle.
Hopefully that made some sense. Cheers!
Patrick Feeley is offline
post #4 of 7 (permalink) Old 03-14-2010, 05:37 AM Thread Starter
misterfruehling
Re: IPR question
thanks i thought that might be it
1999 CB f350 dually
post #5 of 7 (permalink) Old 03-15-2010, 09:46 PM
EVL PSD's Avatar
Re: IPR question
how did you know the IPR was bad?was there a code or something.
95 F-350 4X4 5spd PSD cai,dp,stacks,guages,4 inch lift
EVL PSD is offline
post #6 of 7 (permalink) Old 03-18-2010, 09:32 PM
Send a message via MSN to lopp
Re: IPR question
is there any way to clean a ipr or test to see if i bad other then a scanner.
lopp is offline
post #7 of 7 (permalink) Old 03-19-2010, 02:55 AM
The Fireman's Avatar
Re: IPR question
You can clean it, put new o-rings in it and re-install, was the tin nut on the back of it tight?
Bryan
97 F250 SC LB 4x4 Auto 368,000 miles, AD's, 3in down pipe, Straight Pipe,EBPV deleted, DIY Intake, Racer X converter and valve body, Beans tunes
The Fireman is offline
