Stumbled, died and will not restart - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 04-25-2018, 12:49 AM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Had ZERO fuel pressure, Put a advance fuel pump in and still has has no fuel pressure.
Bad fuel pump? Possible regulator?
After cranking with filter out, the fuel level does not change, and then drains back thru fuel pump
Bradbilt is offline
post #2 of 7 (permalink) Old 04-25-2018, 03:44 AM
79jasper's Avatar
Re: Stumbled, died and will not restart
Well......
Dollars to donuts the shower heads broke off.
If you can, pull the senders to look. I fixed by running a piece of hose with a brass tee to the bottom of the tank. Still had to blow out the lines. (Be prepared for a mess. And tank the fuel caps off lol)
79jasper is offline
post #3 of 7 (permalink) Old 04-25-2018, 09:55 AM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Would that allow the fuel to run back out of the fuel bowl?.
Also, forgot to mention.
White smoke when cranking.
450-500psi injector pressure
3-500rpm
Bradbilt is offline
post #4 of 7 (permalink) Old 04-25-2018, 04:11 PM
79jasper's Avatar
I can't say. I can think of any check valves. Unless there's one built into the lift pump.
(Well, I think the fittings to the heads may have a check valve.)
79jasper is offline
post #5 of 7 (permalink) Old 04-26-2018, 06:39 AM
Terminator Nation
Originally Posted by 79jasper View Post
Well......
Or just add fuel so the tank is over 1/2 full.
old man dave is offline
post #6 of 7 (permalink) Old 04-26-2018, 01:52 PM
79jasper's Avatar
That would be a good test, unless there's crap in the lines.
79jasper is offline
post #7 of 7 (permalink) Old 04-27-2018, 11:29 AM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Going to try just siphoning some fuel from the fuel line with a hand pump
Bradbilt is offline
