No start!!! New turbo, injector o-rings, fuel pump, ipr and icp - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 04-23-2018, 07:31 AM Thread Starter
Hey all...Truck is a 97 350 with a 5-speed. The turbo was shot and it was getting a little harder to start when cold, so i swapped the turbo and gp's and all of the major sensors and o rings while i was in there. I cant get the truck to run now on its own, but i can get it running on a little ether (glow plugs unhooked). If the rpms stay above 1500, i can keep it running on its on power, anything less than that and it just shuts down. Going tomorrow to get a hose and a gauge made up to check the hpop. However, i did hook air to the driverside gallery and it sounds like air is coming through all 4 injectors. (Thru the oil exhaust, not the o rings). To me this says the poppets are worn, correct? Is the ether just helping the pump build the extra pressure it needs to run? Just trying to get a good handle in what is wrong. Looking more and more like i need to order injectors and a hpop. Thanks for any insight.
Bflow55 is offline
post #2 of 8 (permalink) Old 04-23-2018, 12:40 PM
Re: No start!!! New turbo, injector o-rings, fuel pump, ipr and icp
Whats your fuel pressure?
jrdonicht is offline
post #3 of 8 (permalink) Old 04-24-2018, 03:52 AM Thread Starter
45 psi while starting
Bflow55 is offline
post #4 of 8 (permalink) Old 04-24-2018, 12:24 PM
Did it at least run before you changed all the major sensors? If it did I always trace back to what I have just changed and see if its something I did or a faulty sensor. Hope you get it. I cant comment on the poppet valves. Just dont have enough knowledge there. What was wrong with the turbo? Were the blades damaged{dusted engine?} Did you do a compression check?
post #5 of 8 (permalink) Old 04-24-2018, 06:07 PM Thread Starter
Just checked the hpop. Deadheaded pressure was around 3500psi. My guess is a high pressure leak somewhere in heads.
The turbo was just worn, had a bad thrust bearing and was starting to leak. Compression was still good on all cylinders.
Bflow55 is offline
post #6 of 8 (permalink) Old 04-24-2018, 06:36 PM
Moderator
Sbluke55's Avatar
Ok so deadhead one head them the other. That will tell you what side has the issue.
01 f-250, Standard
Sbluke55 is offline
post #7 of 8 (permalink) Old 04-24-2018, 08:26 PM Thread Starter
2000 psi on passanger side, 0 on driver's 😳. Guess i will be trying a new set of o-rings.! I dont see any oil pissing out of injectors
Bflow55 is offline
post #8 of 8 (permalink) Old 04-24-2018, 11:00 PM Thread Starter
Hooked air to the drivers side head and got air coming out of the exhaust spouts on injectors. There was nothing for a few seconds, then three of the four started blowing air out.
Bflow55 is offline
